| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
SS brake line install
#2 (permalink) | |
Super Moderator-Sponsoring Member
Staff
Quote:
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#3 (permalink) | |
Quote:
Well... i pretty much figured the part out about it being messy lol. I was just wondering if there was a "neat" way to do it. To prevent leaks. But... i guess not. |
#4 (permalink) | |
Quote:
What about when i'm washing out my bucket? |
#6 (permalink) |
Yeah what Brian said. Basically knock off the old clips, unbolt the old lines, bolt on the new lines, put the clips back on. I got my lines from Wheelers as well; they came with everything you need.
Re: old fluid. See if your neighborhood or city has an annual clean-up for you to dump your old junk, i.e. automotive oil/fluids, batteries, etc. That's where I took mine last year. Or you can take it down to the local transfer depot, but they may charge a fee. |
#7 (permalink) |
__________________
-Rob Slightly Modified 2001 Tacoma - WATRD.COM WATTORA is becoming NWToys! Tread Lightly! certified Tread Trainer Search 100+ Toyota tech sites, including this one: Toyota Tech Search |
#8 (permalink) | |
Quote:
(sorry, if i seem pretty gullable) |
#9 (permalink) |
No. It will kill your lawn and end up in the water table.
The sign is from the movie "Fight Club". They are trying to cause the complete breakdown of western civilization and it is part of the misinformation that they spread.
__________________
#10 (permalink) |
oh sh#$%t I just dumped 20qt's on my lawn.....I thougt it was true.
Any ideas on how to clean up?? |
#11 (permalink) |
Consider seeking professional help for both you and you lawn. Perhaps just paving over it would be best in your case.
__________________
#12 (permalink) | |
Quote:
Ok... back on topic. If i use a bucket... it will probably be in my best interest in the future to throw the bucket out? I know that brake fluid will corrode paint. So i'm going to assume it's NOT safe to use the same bucket that you use to wash your truck to catch the brake fluid? Also... is the brake line still pressurized when the truck's engine is off? If there's no pressure in the line, then it shouldn't spray out right? It will only drip? thanks |
#13 (permalink) |
It won't spray unless you are standing on the brake pedal when you crack the fitting. It's going to come out as a trickle.
__________________
#14 (permalink) |
Ok good... i was worried about getting some on the paint, or worse yet, getting sprayed in the face. lol
#15 (permalink) |
Easy to swap out. Get a set of vacuum line caps and find out that fits over the brake hard line to keep the leaking to a minumum. I use a vacuum brake bleeder to do mine (should cost about $30) or you can pop for a pressure brake bleeder (around $70) to make the bleeding/flushing easier. Whenever I touch my brakes, I pick up a qt. of fresh fluid and then flush that through the system. Since my vacuum bleeder has a 4 oz. cup, I pull 4-8 oz. out per bleed nipple and that pretty much fill thes system w/ new fluid.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Installing SS Brake Line Extension | ssbogger | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 11-23-2005 03:09 PM |
| SS Brake Lines | turboale | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 12-15-2004 05:27 AM |
| SS Brake Line Problems | WatsonMD | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 12-23-2003 08:17 PM |
