squeaking belts...
Old 12-20-2004, 05:59 PM
Amir904's Avatar
squeaking belts...
mornings when i start up, the engine is squeaking very loud. i just got my timing belts and other belts changed 2000 miles ago. is it my belts? or my pulleys? or what? after driving for couple minutes, the sound goes away.
Old 12-20-2004, 06:07 PM
dwh91102's Avatar
make sure the belts are tight......the timing belt won't slip if it does you got problems if the tighting doesn't work you can try the old soap trick
Old 12-20-2004, 06:08 PM
dwh91102's Avatar
Old 12-21-2004, 05:12 PM
Amir904's Avatar
well the stealer did the job, ill just go back and tell em. btw what is the soap trick?
Old 12-21-2004, 08:05 PM
lee
lee's Avatar
belt dressing may quiet it, but most likely as dwh said, the belts need to be tightened up... i just solved this same problem...
Jake28296
09-03-2015 04:58 PM
camdenbuck
07-07-2015 07:33 AM
Ladythump
07-04-2015 03:35 PM
FirstToy
16
01-14-2012 03:11 PM
Quick Reply: squeaking belts...
