spark plugs for better mileage?
I didn't see this until today. Sorry for the long delay in the reply. This board moves posts down fast.
To answer your questions:
Wosrt case scenario would be a blown engine. Most likely what would happen is that it simply wouldn't run or it would run ˟˟˟˟˟ty. You prolly wouldn't have to upgrade the fuel system as there is plenty of headroom in the system to allow some more air to flow. You could also look into an oversized Throttle body as a lot of people seem to really notice a nice improvement with those on these engines. There are several companies that make them for these engines. Cost is around $260 with a core.
You could still do the ECT mod, but I'd try just Advancing the timing first.
Hope this helps.
Dr. Z
In the event that the ECU couldn't deal with the new readings coming in from the AFM what would be the symptoms in the worst case senario and could engine or ECU damage result? If the ECU can handle it, would the fuel system have to be upgraded with the higher fuel demand?
ps - another idea, if i advance my BTDC timing to 12*, can I still safely do the ECT mod? Or will pinging give me that answer?
Thanks
Thanks
Hope this helps.
Dr. Z
Originally posted by livelarg
Allright, it is time for me to show how dumb I am.
I have been following this thread, but all of the abbreviations are throwing me off.
I know that the AFM is a air flow meter, but what is it and where is it?
I know what a ECU is.
But what is the FIPK that everyone is talking about?
Also Dr.Z
Would your reccomend the Magnacore wires, and the iridium plugs you have for a 88' 3.0?
Did thay make any difference for you?
Also Dr.Z
These are made by K&N. Just do the ISR mod for the 3.0 instead. It's way cheaper and a lot more effective.
I bought the Magnecor's for cheap insurance and piece of mind. I did notice easier cold starts after installing them. The Iridium's are nice, but no better than ordinary plugs on my truck it seems. They may work better for you since your spark energy output from your ignition system is most likely lower than the 3.4's.
Hope this helps.
Dr. Z
I just did the ISR removal mod yesterday.
It seems to be a little quicker and more responsive. and it makes a nice roar when accelerating!
I like it so far. I am looking for an AMSOIL air filter next. I will have to order it.
I think I am going for the NGK V-power plugs. I don't think the extra cost of the iridiums is worth it for my old engine.
Thanks
Kent
Thanks
Kent
#25
I may be wrong, but I was on the Amsoil website and checked for one for the 3.0. According to the site, they have one the filter number is AF894. but it is listed as a Hastings
I am about to order one for my truck. The site says it takes 3 to 4 weeks for delivery. I will let you know if it is actually the right filter.
montanatruck
02-26-2017 07:07 AM
defrag4
07-31-2015 10:50 AM
