spare tire removal help
Old 03-25-2003, 10:22 PM
Skydigger's Avatar
Ok. I've got this '86 4Runner with the spare mounted underneath and I'm having a heckuva time trying to remove it.
I've been applying liquid wrench for the past few days and have stripped the Toyota rod using force to unscrew it.
Anyone have any suggestions on how to get this unstuck and out?
Thanks,
Warren
Old 03-26-2003, 04:02 AM
1Runner's Avatar
Had the same problem w/ my 85 xtra cab. I had to use a torch and cut out the center holding the tire up.
Good idea, bad design.
Old 03-26-2003, 04:34 AM
Firefyter-Emt's Avatar
Before you cut it... look underneth, and see if you have a gearbox to the left try disconnecting the rod going to that gearbox and see if you can let the "tire winch" down that way... I cut mine only to find that the winch was fine and the gear box was frozen.. So I orderded a new winch... and then the gearbox! (Yep, they are not cheap nor come togather!!)
Old 03-26-2003, 04:59 AM
Cebby's Avatar
My gearbox was seized this winter when I needed my spare. I doused it in WD40 and beat on it with a hammer. It freed it and now it works fine.
Old 03-26-2003, 05:51 AM
dusty98's Avatar
I used some spray I picked up at Walmart, I've seen at other stores too. Don't remember the name, but the can has a yellow top, white label with black & red writing. Kinda looks like a newspaper article.
Smell is really, really strong so be aware of that. I sprayed it and let it sit for about 10 min, then I was able to loosen the mechanism. Now I spray the mechanism once a year with oil and cycle it to keep it from seizing again.
Good luck...
Old 03-26-2003, 12:29 PM
Skydigger's Avatar
Thanks for the ideas guys. I'll try 'em out and let you know.
Warren
Old 03-26-2003, 01:47 PM
dajabr's Avatar
I used a liberal coatinng of WD-40, soaked, coated, soaked. Then jam the cranking rod in the socket and smack it with a hammer several times. Mine was frozen solid until I did this, once I started it moving and kept reapplying it freed up and worked fine from then on. Took about 30 min.
09-04-2015 09:27 AM
DrZero
18
07-24-2015 11:31 PM
DrZero
07-13-2015 09:59 AM
crashburnoveride
07-10-2015 06:39 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: spare tire removal help
