SOS - Defroster - rear window and mirrors ?
Old 03-01-2007, 08:27 AM
alotawatts's Avatar
My wife is on the road in our 2001 ...asking about non-working rear window and mirror defrosters.
I there a dedicated fuse for these ?
thanks
Old 03-01-2007, 08:51 AM
Guest
seanz0rz's Avatar
make sure you rear window is rolled all the way up, otherwise the defroster wont work. to test this, roll it all the way up and try to use the rear wiper. if it works, then there is something wrong with the defroster circuit, if it doesnt, then there is something wrong with the cutout switch in the rear door.
as for the mirrors, didnt know they ever came with heated mirrors.
Old 03-01-2007, 11:19 AM
eric-the-red's Avatar
The rear defroster and mirror heaters are on seperate fuses, both in the fuse box under the hood. The are both controlled by the DEFOG relay, and also by the same switch. Like seanz0rz said make sure the window is up all the way. If it is and the wiper works then it could be the relay. The PWR OUTLET relay is exactly the same as the DEFOG relay so maybe try swapping them and see if that helps.
Old 03-01-2007, 03:02 PM
alotawatts's Avatar
Follow up - Thanks
Wife calls back-
Yup -
Window was not 'closed completely'
Thanks y'all
When your wife is happy..............you're happy
Old 03-01-2007, 06:45 PM
That's for sure. Glad it wasn't something more serious.
06-01-2021 01:51 PM
lledwod
08-30-2016 01:03 PM
coreyedwards7611
01-16-2016 06:38 PM
sabine
07-18-2015 03:59 PM
icentropy
07-14-2015 10:23 AM
Quick Reply: SOS - Defroster - rear window and mirrors ?
