So THAT'S why my tailgate window wouldn't go down...
Old 07-02-2007, 05:42 PM
Hugo's Avatar
This is the driver's side window track.
Oh, and I need to change the other one too... Cha-ching!
Old 07-02-2007, 06:06 PM
Texas_Ace's Avatar
How the heck did that happen to it??? Your sig says a 99, i have no idea how that could of happend. But OUCH!
Old 07-02-2007, 06:20 PM
Hugo's Avatar
Not only did it happen, but it happened like a couple of years ago. My rear window dropped into the tailgate because the flange that support the window got damaged. The metal parts rusted, and the plastic got brittle, and it failed. I fixed that with a couple of nuts and bolts, but the window wouldn't go down completely. I now know why. The rust made the metal ?inflate?, and the window guide would get stuck there...
I recently bought a new motor assembly, too.
Water simply gets in there, and everything rusts.
Old 07-02-2007, 06:36 PM
Texas_Ace's Avatar
Hmmm, that is scary.
But i also see that you live way up north so i guess you have salt (this is something i know nothing about down in Texas). That could be part of your problem...
Old 07-03-2007, 07:13 AM
sharrack's Avatar
IMO.............The biggest culprit in the 3rd gen tailgates is the 2 cent
black filters on the bottom of the tailgate.
They will be clogged in no time and any dirt, dust and moisture is trapped in your tailgate to reak havoc on your parts.
I pulled mine out and tossed them a while ago and now, any water runs right out the bottom of the tailgate along with debris and dirt.
The first flushing was a doozy with huge cakes of sediment breaking apart and coming out.
Also.........As a rule, I never 4 wheel or trail ride with any window at half mast.
A recipe for a jumped track or dropped window or broken parts.
fully open or closed when offroad. Kenny S>
Old 07-03-2007, 01:31 PM
Texas_Ace's Avatar
I will have to try that.
And fully clsed i can see being the best choice but how is fully open safer than half open? Seems that they are both the same.
Old 07-03-2007, 01:45 PM
881stGenRunner's Avatar
when not all the way open/closed they are in the middle of the track and have potential to come off the track and not go back up/down. If it is all the way down then it is all the way inside the track and cannot go anywhere.
Old 07-03-2007, 02:24 PM
sharrack's Avatar
IMO....... a half mast window has much of it's weight flopping in the breeze
while you vibrate your way down the road
A fully open window is grabbed at the bottom by the track and at the top by the firm rubber gasket on your door. Keeping it in place.
Experiment for yourself..........1/2 mast the rear window and go four wheeling
You'll hear many interesting sounds emitting from your tailgate as the flopping begins.
Old 07-03-2007, 02:27 PM
Texas_Ace's Avatar
Ok, that makes sense. I usually wheel (well mild wheeling as i can't afford to break anything until i have another DD truck...) i have all but the driver windows closed.
1uzRunner
63
11-10-2018 03:58 PM
mat
09-17-2015 11:18 PM
Jeff Keller
09-13-2015 12:40 AM
Quick Reply: So THAT'S why my tailgate window wouldn't go down...
