so my transmission died...
Old 02-06-2007, 05:58 AM
  #61
MTL_4runner's Avatar
Lee, thanks for posting those pics of what happened!!!
......just sucks that it was the planetary (mucho $$$$) that went.
That aluminum casing and steel parts are worth a few bucks to a scrap metal dealer so cash that stuff in!
Old 02-06-2007, 06:19 AM
  #62
lee
lee's Avatar
too late
thats ok, i am gonna try to sell the oil pan and the front and rear of the casing.. if i cant ill turn the front and rear in to a metal dealer as you said...
oh well. it happened and at last i got to crack it open and learn about it.. its really fascinating. i cannot believe what goes into an auto tranny.. i mean, the engineers are ˟˟˟˟˟˟ geniuses!
Old 02-06-2007, 06:21 AM
  #63
mastacox's Avatar
Originally Posted by lee
too late
So lee, what kind of shape is your valve body in?
Old 02-06-2007, 06:27 AM
  #64
lee
lee's Avatar
i wouldnt feel comfortable selling anything besides what i said above... everything was covered in metal pieces, not to mention once i realized there was no saving the tranny, we were less careful about taking things apart.
Old 02-06-2007, 06:34 AM
  #65
mastacox's Avatar
lol oh well, it was worth a shot
Old 02-07-2007, 04:49 AM
  #66
BOSTON4RUNNER's Avatar
I wonder if a sythetic fluid change would help act as cheap insurance - it is a fact that synthetics run at cooler temperatures and am sure that heavy off roading really heats it up.
I run synthetic in my 5 speed and it definitely made it shift alot better - also have it in my rear axle.
I am not sure what the Toyotas have for a factory transmission cooler, probably only runs through the radiator - jumping up to a serious and large capacity one, mounted behind the grill may also help ensure transmission longevity
Old 02-07-2007, 04:51 AM
  #67
No matter what the application - racing, off roading etc - stock parts will only take you so far, however doing minor upgrades such as what I mentioned for the tranny may help out alot...
Old 02-07-2007, 04:53 AM
  #68
I would maybe even do this, with a fan. Drive on the street with the cooler in place, then during heavy of road crawls etc have a manual switch set up to turn on the fan.
Old 02-07-2007, 05:12 AM
  #69
lee
lee's Avatar
yeah ive already mentioned a few times that ill be adding a transmission cooler.
i need to pay this down a bit first.
Old 02-07-2007, 05:27 AM
  #70
I hear you - the cost of replacing a major item can really snap your balls off
when you do go to do it, I would lean towards the overkill - one with a fan etc, that way do it once
Old 02-07-2007, 05:46 AM
  #71
Reldnew's Avatar
You say it has "slipped since 44,000mi." If that slipping condition was caused by the thrust washers failing and it still took till 113,000mi before complete failure, you made out OK. That means the planetary gear set took 67,000mi of abuse before grinding themselves to bits.
Old 02-07-2007, 05:51 AM
  #72
lee
lee's Avatar
yup, basically
Old 02-07-2007, 06:44 AM
  #73
mt_goat's Avatar
Good Lord, wouldn't that make a lot of noise? I've heard guys say their tranny sounds like a can of marbles before.
Old 02-07-2007, 06:48 AM
  #74
mt_goat's Avatar
2- fluid was changed last sept.
Any sign of metal fragments at that time?
Old 02-07-2007, 07:46 AM
  #75
lee
lee's Avatar
i took it to firestone, and never asked. so i would assume they did it in such a hurry that they didnt even look.
Old 02-07-2007, 08:15 AM
  #76
Lee, did the place that installed your new tranny flush the internal radiator tranny cooler by any chance?
If not it might be worth just pulling and cleaning the filter after 5k or so.
Old 02-07-2007, 08:27 AM
  #77
lee
lee's Avatar
good question, ill ask.
thanks for the tip
Old 02-07-2007, 05:28 PM
  #78
RunnerUp's Avatar
wow lee, that sucks! i had to replace the tranny in my 99 at 65k right before i totalled it, this one seems fine right now, though i do jolt when i accelerate from a stop sign sometimes... im just hoping that its my rear diff instead of the tranny! buy a lotto ticket, maybe you'll get lucky
TheBFA
02-15-2020 06:55 AM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
Odin
09-26-2015 06:56 PM
toyotasaurus
09-24-2015 03:30 PM
briholt
09-20-2015 10:26 PM
Quick Reply: so my transmission died...
