So 8.25 tacoma diff and 3rdgen differnt??? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-24-2003, 11:35 AM   #1 (permalink)
Ok so are the tacoma standard 8.25 rear diffs and the 4runner rear diffs the same or differnt? In other words can they be interchanged?
And can a electric locker be put into a stock 4runner 3rd gen housing with some light fab work? I know you can't do that in a tacoma?
And I understand the 4runner 3rd members are the same as the older v6 diffs and the 4cylinder turbo diffs?
Is this all right?
Just trying to check out my options
Yes I have seen the toy tech axle site but it don't really answer these questions.
Thank you
Jason DeMello
JDeMello is offline
Old 09-24-2003, 11:47 AM   #2 (permalink)
Flygtenstein's Avatar
All 4wd 3rd Gen runners have 8" rear diffs.
E-locked Taco's have 8" diffs as well.
These diffs are interchangable with rears on 4wd Toy trucks from 86 to 95, front or rear Toy trucks from 79-85 and rear 80's series cruisers from 91-97. Cruisers have high pinion fronts that are the same size diff, but they are high pinion, so they are less durable in rear applications. All the rest, pull the third and stick IIRC.
All e-locked diffs should be V-6 gears.
The housings listed above are all 8" Toy. The gears and carriers will have 4 cyl to 6 cyl differences.
Non-TRD Taco's as well as open diff'd should have 8.25" diffs as well as some T-100's.
I think this all comes out about right.
Flygtenstein is offline
Old 09-24-2003, 02:12 PM   #3 (permalink)
So a elocked diff like the one in my taco will fit the rear 4runner 3rdgen housing?
But my spare 8.25 standard taco rear diff won't fit my 3rd gen 4runner?
What about gears? I know the 8in and the 8.25 are differnt but what about the 4runner? Does it have the same ring and pinion as my taco e-locked?
JDeMello is offline
Old 09-24-2003, 02:56 PM   #4 (permalink)
Send a message via AIM to justinh
you will have to do a little grinding and welding on the housing of the 4runner rear axle to put the e-locking differential in there. it has been done many times and some members on this board have done it.
justinh is offline
Old 09-24-2003, 04:02 PM   #5 (permalink)
Your 8.25" diff will not fit your runner.
Think about it like this, and I only mean metaphorically, one is a Dana 60, one is a Dana 44. They are different axles.
Your 8" runner housing will need to be modified to accept the e-locker.
No amount of modification will get a 8.25" diff working in an 8" housing.
Your runner has an 8" diff. All 6cyl 8" gears will work in it. 4cyl gears will work with shims. 8.25" gears will not fit.
Old 09-24-2003, 05:38 PM   #6 (permalink)
sschaefer3's Avatar
Actually all 1996-2002 4Runners, reguardless of 4WD, 2WD or 3.4, 2.7 have the V6 8" diff. They are all the same. All 4WD have the 7.5" front diff.
The original engine and tire size dictated the gears which range from 3.70 to 4.56.
The transmission and transfer cases are different between the 3.4 and 2.7. Obviously the 2WD 4Runners have an even different transmission.
All 1996-2002 4Runners were made in Japan and have slightly different Japaneese made parts than the Tacoma. The same part will not be "exactly" the same. Japaneese supplier versus North American supplier.
__________________
Steve Schaefer
WWW.SonoranSteel.Com
Suspension Lift Kits * Rock Sliders * Straight Axle Conversions * 4Runner/FJC Rubicon Express Lower Links * Accessories * Daystar Products Dealer * TJM Bull Bar Dealer * Deaver Leaf Spring Dealer * Tokico & Bilstein Shock Dealer * ViAir Dealer * Total Chaos Dealer * TOYTEC Dealer * and like everyone else a Trail Gear Dealer
sschaefer3 is offline
Old 09-24-2003, 07:50 PM   #7 (permalink)
Thanks that would explain why the 98 4runner we had never had a problem and the 99 tacoma we have has had little things.
JDeMello is offline
Old 09-24-2003, 08:27 PM   #8 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
Quote:
Actually, the FJ80 rear has the same 9.5" diff as the earlier FJ40/45/55/60/62
or is it the 8.875? Not sure, but it's definetly not 8" like 4Runners
Adam F is offline
Old 09-24-2003, 09:13 PM   #9 (permalink)
sschaefer3's Avatar
8 7/8" is what the FJ-62 has.
__________________
Steve Schaefer
Old 09-24-2003, 10:12 PM   #10 (permalink)
Thank you for the clarity gents. In my interest of being complete, I over stepped my bounds.
Moral of the story is the Runners and non e-locked Taco's have different diffs.
Old 09-24-2003, 10:33 PM   #11 (permalink)
44Runner's Avatar
Send a message via AIM to 44Runner
The FZJ-80 got the true phatty Toy diff. True to LC form, Toy had to make these old rears different from the rest of the Toy stuff, so they of course had crappy C-clips. The FZJ-80 got the phatty full floating version of this axle...
44Runner is offline
Old 10-02-2006, 12:11 PM   #12 (permalink)
RR DIFF LOCK's Avatar
Sorry to resurrect an old thread here, but may I clarify the part #'s for the correct lockers for my application? (1999 4Runner Base Wagon 4WD 2.7L 4cyl)
Detroit EZ Locker: 813A015
Aussie Locker: XD-20830
Powertrax Lock-Right: 1620
ARB Air Locker: RD23
Are these part #'s correct? Thanks in advance for your help.
__________________
Scott - Gilbert, AZ
'97 TOYOTA 4Runner Limited 4WD, 3.4L V6 with A/T, Factory Electronic Locking Rear Differential, Sonoran Steel Lift System # 7.1, AIRAID MIT, TrueFlow Air Filter, Jardine Cat-Back Exhaust, LT285/75R16 Pro Comp Radial XTerrains
SOLD: '99 TOYOTA 4Runner Base 4WD, 2.7L 4-cylinder with M/T
RR DIFF LOCK is offline
Old 10-06-2006, 01:16 PM   #13 (permalink)
So as an FYI to anyone who cares, Bill from Aussie Locker informed me that they will soon be releasing the TOYOTA 4-pinion rear. This will be the correct part for my application and any other 3rd gen 4Runner if I am not mistaken (treading lightly here). Part is expected in the next few mos, along with some other applications including the Tundra.
__________________
Scott - Gilbert, AZ
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
differnt kind of alarm sensors weakyota91 Alarm Systems 1 05-20-2007 11:42 AM
IFS Diff Swap - Will 97 4runner V6 diff fit in 99 Tacoma 4cyl? transalper 95.5-2004 Tacomas & 96-2002 4Runners 5 03-21-2007 06:26 AM
do manual and auto trucks have differnt crankshafts? Eric 95.5-2004 Tacomas & 96-2002 4Runners 8 01-29-2005 04:14 PM
center diff. locker for Tacoma? stumblyjoe 95.5-2004 Tacomas & 96-2002 4Runners 16 09-03-2003 11:34 AM
2009 InternetBrands, Inc.
