Slight Backfire/Misfire at Startup
Old 05-01-2014, 03:37 PM
Zach99SR5's Avatar
Exclamation Slight Backfire/Misfire at Startup
History: 99 4Runner SR5, 3.4 2WD, Auto
About a year or so, have had some starter trouble, just clicks, but eventually starts. Problem will come and go.
3 months ago had a P0301, cleaned out MAF sensor, IAC valve and throttle body.
Then replaced fuel filter, all 6 plugs, wires, Cylinder #1 Coil Pack and Cyl#1 Fuel Injector. Problem fixed.
Problem: About a month ago, starter is CONSISTENTLY trouble! Just Clicks and/or, at times, will have a slight slight backfire with a mild misfire feeling/sound.
No Codes have been banked. I do have new contacts for the starter, will replace them within the next week, time permitting.
Also, just passed smog 3 days ago with flying colors.
Question: Any ideas regarding the backfire/misfire? Troubleshooting?
shooter86314
01-07-2016 07:05 AM
Ditch Doc
10-27-2015 03:20 PM
the_supernerd
10-01-2015 09:20 PM
dbollier123
09-29-2015 05:23 PM
langry345
09-14-2015 03:36 PM
Quick Reply: Slight Backfire/Misfire at Startup
