Should i rebuild or not??
ok guys u might save me alot of money here.. i have a 3vz-e and the h/g blew not to long ago.. the motor has 185,000 and when the h/g blew the motor hydro-locked.. what my ? is should i rebuild th entire motor or just replace the h/g???
Depends...
On how much time and money you want to throw at it.
Most here will tell you: Swap a 3.4 into it. And for many good reasons...power and mileage come to mind.
However, if you need to be mobile by Monday, I'd say rebuild it or just swap a used 3.0 into it.
You DID check to see if the recall was valid, right???
Originally Posted by TOYOTA4LIFE
its a 89 toyota p/u they said it was never on recall..
Too bad...
Dale Johnston
11
10-31-2015 10:22 PM
