| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
shifting in and out of 4x4
__________________
current rides: 89 4-cyl 5-speed 4runner, 32x11.5 BFG AT's, 2" butt lift, wet okoles seat covers, Sony cd+mp3 deck with 100W pioneers and a 1200W sub system, and a slightly altered 2nd gen's brush guard. also have a 1997 yamaha fzr600 |
#2 (permalink) |
Remember that when you are in 4 wheel drive, that all four wheels are coupled together. So (ignoring lockers, limited slips, and the like) when you are coasting, the front wheels/front driveshaft and rear wheels/rear driveshaft are all spinning together (and spinning the transmission). This is nearly twice the drag as when you are in 2 wheel drive, because in 2 wheel drive only the rear wheels/rear driveshaft are mechanically coupled to the transmission. So basically, you have more drag.
Your second issue sounds like the diffential had engaged but not unlocked. If I shift from 4-Hi to 2-Hi on the fly, I'll usually stay in 4-Hi until I come to a stop (sometimes even after that) because the teeth are still meshed together. A quick tap in reverse (while in 2-Hi) should unlock the teeth and actually move you into 2-Hi. ~Bill |
#3 (permalink) | |
Quote:
__________________
#4 (permalink) |
Your second issue (from the '96 owner's manual):
To shift from "H4" to "H2", simply move the front drive control lever. This can be done at any vehicle speed. If the indicator light odes not go off when you shift the transfer into "H2", drive straight aheah while accelerating or decelerating, or drive in reverse. So yeah, that's normal. As for the first issue, I still don't think that's abnormal. I would imagine that when you're coasting "normal" that the diff isn't locked. Remember that unless you have a locker, that the wheels with the least amount of traction are the ones that that get power. This can cause unusual situations. Though someone on the board with more 4-wheel experience than I can probably explain it better. ~Bill |
#5 (permalink) |
im not sure on the first part, but the second part i can explain, it is caused by drivetrain wind up, when you are in 4wd both drive lines have to turn at the same speed, because they are mecanicly linked together, so when you are in 4wd slight differences in tire dameter will bind up the drivetrain and also when you steer, that will also bind it up, and you will not be able to shift it until you relive that stress by backing up or turning back and forth slightly while putting pressure on the transfer case shifter, so when the stress gets relived it will slide out, but in 95.5 with the taco and 96 with the 3rd gens, toyota did something different, they made a spring loaded transfer case shifter so that you can move it out of 4wd, but it will acually remain in 4wd until the driveline bind is relived, it wil then shift into 2wd by spring force, i hope this clears it up
__________________
- Joe 1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks 1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs Last edited by superjoe83; 05-18-2004 at 02:08 AM. |
#6 (permalink) |
One thing I will tell you with your truck is DO NOT!!!
do any kind of shifting in and out of 4wd while you are moving. I have the same setup as you and your transfer case is gear driven. If you decide to shift into 4wd at speed your transfer case will BLOW UP. What these guys are talking about is "shift-on-the-fly". The reason they can shift into 4wd at 45 miles per hour is because they're t-cases are chain driven, and I think they are sychronized like a multispeed bicycle, allowing it to shift gears at speed.Always lock your hubs before you get into 4wd. Once your all shifted in, go in reverse about 10 to 20 yards, this locks everything up in the front. Then you're ready to roll. When you're ready to get back into 2wd:stop, unlock the hubs, and reverse about 10 to 20 yards again. With the hubs unlocked, this allows everthing to unlock and you can shift your t-case back into 2wd. It sounds like alot of work but this setup is a crapload stronger that the chain drive t-cases and automatic hubs. I'm about 99% sure on everything I've told you, but if anyone has anything to correct me on, feel free.
__________________
1989 pickup, 4x4, 22re 4" superlift (full rear springs, skidplate), dual steering stabilizer, downey 26mm torstion bars, 1.5" rear shackles, low profile bumpstops, 5.29's w/ V6 3rd, 35x12.5 BFG MT's on AR Outlaw II 15x10's, 2" wheel spacers, custom exhaust (pacesetter header, 2.25" single in/dual out flowmaster delta 40) custom built 3" intake with stock replacement K&N, LCE water pump, flex-a-lite fan, optima red top My truck site |
#7 (permalink) | |
Quote:
__________________
#8 (permalink) | |||||
Quote:
Quote:
Quote:
Quote:
Quote:
__________________
-Glenn- Last edited by Glenn; 05-18-2004 at 07:14 AM. |
#9 (permalink) |
I'm going off what one of my friends said. He was driving down the road and a girl that was riding with him hit the t-case shifter and it blew up his t-case. On the visor in my truck it says NOT to shift into 4wd unless you are under 5 miles per hour and not unless the hubs are locked. I don't know about that ADD stuff, don't have it and don't know much about it. I'm going on personal experience and what I've heard and read. I just hope you're not calling me stupid.
__________________
#10 (permalink) | |||
Quote:
Quote:
Quote:
I have been driving manual hub 4wd trucks for over 20 years. There really is no mystery to how the system operates.
__________________
-Glenn- |
#11 (permalink) | |
Quote:
When you have your hubs locked it spins the front driveshaft , though it is not connected to the T-case, so if you shift into 4wd while moving both driveshafts will be spinning at the same speed, so no problem. With unlocked manual hubs, the front driveshaft is stationary, so at speed, you are making the tcase move the large driveshaft from a dead stop to whatever high rpm you are at (driveshafts are spinning much faster than the tires, because there is another gear reduction in the diffs, so just imagine the strain). So don't shift while moving with unlocked hubs, and also be weary about shifting into 4wd if your backtires are spinning (without traction) with the front hubs locked, because again, the driveshafts will be going at different speeds. 4low you should always stop to shift into, this is just good safe practice. Also, don't drive over 25 miles per hour in 4lo, because the gears and everything are spinning 4-5 times as fast. You can blow things up this way. Ayoung, one tip listed in my owners manual, maybe even yours is to goose the throttle while putting pressure on the stick to move from 4wd to 2wd. It works for me everytime. I've never had a problem getting out of 4wd since I discovered this. You don't have to go ape wild, just a quick romp on the gas will do it.
__________________
1987 Xtra Cab (4x4) - (SOLD) 22r, Rancho RS 5000, 15x8 American Racing AR-23s w/ 31x10.5 BFGoodrich A/T's, 2.25" exhaust w/ 23 1/8" glasspack, Explorer Pro Comp Prerunner bar/ Hella 500's |
#12 (permalink) |
Ahh got ya. Sorry, didn't mean to sound like an a$$. Now it makes sense. Thanks for the good explanation. I didn't get an owners manual with the truck when I bought it off the guy, so that didn't help any.
__________________
1989 pickup, 4x4, 22re 4" superlift (full rear springs, skidplate), dual steering stabilizer, downey 26mm torstion bars, 1.5" rear shackles, low profile bumpstops, 5.29's w/ V6 3rd, 35x12.5 BFG MT's on AR Outlaw II 15x10's, 2" wheel spacers, custom exhaust (pacesetter header, 2.25" single in/dual out flowmaster delta 40) custom built 3" intake with stock replacement K&N, LCE water pump, flex-a-lite fan, optima red top My truck site Last edited by motrhedx81; 05-19-2004 at 04:11 AM. |
#13 (permalink) | |
Quote:
__________________
Dave Currently own no Toyotas :( |
#14 (permalink) |
Toy283 has the answer here guys. No mystery here. There is usually a small diameter difference between the front and rear tires and it matters. If there's a bigger difference (like say if the fronts are real low, or if you're an idiot and don't even have the same size tires front and rear) it will cause the case to bind and not want to come out of 4hi. Another thing, more importantly and this is probably what happened to Young101: drive straight and turn the wheel just slightly side to side. In 4wd bind occurrs in the t-case due to turning too.
Oh, and when coasting with the clutch pedal depressed and turning the wheel even a little bit in 4wd will cause bind, and will feel just like brakes, if the tires had nice grip on surface you're on. Backing up a teensy bit does help, they aren't wrong about that, it can help unload the t-case. Shifting on the fly above 45 is certainly possible, but you should really try to avoid it. If there is any difference in tire diameters (due to inflation) it's amplified as speed increases. But even in practical terms - if conditions cause you to need to yank it into 4hi, you probably need to Slow the Farg Down anyway! <grin>
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| V6 4x4 manual shifting problem | pangura | 86-95 Trucks & 4Runners | 8 | 03-09-2006 01:24 PM |
| bad shifting | Y2Krunner | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 01-03-2004 08:19 PM |
| rough shifting | jsrusse11 | Maintenance & Repair Archives | 14 | 12-01-2003 05:13 PM |
| 4x4 Shifting | 4x4Fink | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 09-04-2003 01:10 PM |
| transmission shifting | trdtacoma01 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 11-26-2002 12:20 PM |
