Runner Lift Questions
Ok, So I have done all my searing and looked around and around. I have a few questions that I cant seem to find straight answers for. Does anyone have a installation guide on these 2 kits? How much "fabrication" is involved with either, or more remove, replace, tighten.
1: ToyTec UL-96024R
2: SS - 1.2
Thanks in advance.
1: ToyTec UL-96024R
2: SS - 1.2
Thanks in advance.
I have the 883/890 set up with comfort shocks. No Fabrication, you are replacing the strut and coil in front and shock and coil in back. You will have to unbolt the sway bar end links for both rear and front to get the arms/ axle to droop down to fit the new suspension. Be careful not to pull to hard on the rear brake line during this process. You may need new upper and lower ball joints for the front if you haven't replaced those in a while.
Are you assembling the front yourself? if so, Place included trim packer on front strut on drivers side.
It's a pretty straight forward process because you have an example already put on your truck.
Most people have a hard time holding down the front control arms as they tighten down the bottom bolt. Here's what I did (use at your own risk):
[IMG][/IMG]
[IMG][/IMG]
1: ToyTec UL-96024R
2: SS - 1.2
Thanks in advance.
1: ToyTec UL-96024R
2: SS - 1.2
Thanks in advance.
They have install instructions on their website and they are all over this forum.
:wabbit2:
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
