RPM's at 70mph for Automatic 2000 4R?
Old 06-03-2010, 08:06 AM
ohio4runner4x4's Avatar
Question RPM's at 70mph for Automatic 2000 4R?
Just had the tranny re-done on my 2000 4R due to the strawberry milkshake......still got problems, but that's a whole nuther issue!
Anyway....It's the wife's vehicle and I hardly drive it. Finally drove it last nite and can't remember what the rpm's were at 70mph. Right now it's about 2150 at 70mph.
Does that sound right?
Thx
Old 06-03-2010, 08:59 AM
AlexJet's Avatar
My 2001 gives me around 2000 with 33s at 110km/h (~69mph), so it sounds fine.
Old 06-03-2010, 11:45 AM
b0n3mast3r's Avatar
mind is some where around 2200-2400
Old 06-05-2010, 12:05 PM
Knightfire's Avatar
Yuppers, I run between 2000-2200 at 70 as well. Sounds right to me.
Old 06-05-2010, 12:15 PM
rideexileex's Avatar
Depends a lot on the altitude you are running at, and a bit on the fuel grade too. I live in both Seattle and in Bozeman (5000ft) and notice a jump of about 250rpm or more - ~2000 in Seattle and 2250 in Bozeman with 285 BFG's
Old 06-06-2010, 09:49 AM
SkidPalace's Avatar
I am a bit confused by some of the responses.
How can your RPMs vary by a few hundred at any given speed.
Unless your TC is not locked up and you are slipping in 4th, your speed at RPM should be constant at a given highway speed like 70 mph. That speed is determined by your final drive ratio and tire size. You should only see minute changes due to tire pressure and treadwear.
Am I wrong about this?
1992pickupSr5
05-09-2019 08:44 AM
DeathCougar
04-01-2018 11:29 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
TURBOrunnerNM
07-20-2015 08:31 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Quick Reply: RPM's at 70mph for Automatic 2000 4R?
