| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Rough idle problem
__________________
'98 4-Runner SR5 V6 Automatic Intake elbow removed, Sony head unit, Sony Class-D amp, Sony 10" sub enclosure and F&R components Brad Hall Service Advisor Nelson Automotive Group 201 Commonwealth Blvd. Martinsville, VA 24112 276-638-2331 www.autosbynelson.com |
#2 (permalink) |
I have a '98 4Runner with the 3.4 and have the same problem I tried the same things (new plugs, wires, O2 sensor, fuel filter, cleaned MAF and throttle body, checked for vacuum leaks, etc.), but I have yet to resolve it or receive any helpful advice.
I'm wondering if a coil pack is going bad. Please let me know if you figure it out because they definitely shouldn't run this way. THANKS! John |
#3 (permalink) |
i think it's common "problem" for all 3gen 4runners. mine has been doing the same thng since the day i bought it. 4years ago. forget about it.
__________________
English is not my native language. i'm sorry for misspeling. |
#4 (permalink) |
Check coils packs and the spark plug connector boots. I had same problem, coil packs were good but spark plug conn. boots were all corroded and tore up (after 11 years of use) and the spark would sparodically jump down the side of the spark plug.
__________________
"Get a lift, fat girls can't jump" My Ride 1996 Toyota 4runner SR5 V6 4x4:3.4L Automatic, 3" ToyTec Lift, 265/75 Cooper STT's, ISR/Deckplate Mod, K&N Air Filter, Brand New 2.5" Exhaust system, 14" Magnaflow Muffler, Front and Rear Aux Lights, |
#5 (permalink) |
Good news, I think. Yesterday, a friend and I ran advanced diagnostics with a laptop. No codes pending or stored. The ONLY problem we could see was that the ECM thinks the engine is running at 221 degrees. The gauge was normal and the engine actually temped normal with a temp gun. We also noticed the timing hunting around up toward 20 degrees BTDC and a rich condition at the o2. The ECM is trying to cool the engine down with timing and fuel. I'm going to get a new temp sensor today and will install it in the next day or two along with a thermostat to be safe. I will let you know what happens.
__________________
#6 (permalink) |
Changed thermostat and coolant temp sensor today. So far, everything is running very smooth.
__________________
#7 (permalink) |
Can the boots on the coils be replaced without replacing the coils?
__________________
#10 (permalink) |
The boots are not sold seperately to the best of my knowledge, but you can use some dielectric grease for using on the boots. If they are bad enough, just buy a new coil pack (or get a used one from a boneyard).
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#11 (permalink) |
rbh261 please keep us updated, is your vibration still gone, I know it hasn't been too long but, my 97 does the same thing (i think) and I would like it to run the best it can, not forget about it. Also, what computer diagnostics program do you have, what did it cost and where did you get it? thanks
__________________
1997 4runner Pop's Just got himself 2007 Toyota Tundra TRD |
#12 (permalink) | |
Quote:
http://www.obddiagnostics.com/ or an Auterra http://www.auterraweb.com/
__________________
#13 (permalink) |
The diagnostics equip looked like the one in the first link. I'll have to ask my friend which one he has. He uses it on a '96 Trans Am LS6. It allows him to disable certain sensors and such. He turned off his o2 sensors behind where his catalytic conv. used to be. He is installing a 6 speed in place of his auto, it allows him to use his current ECM and PCM with the 6 speed. It's a pretty awesome setup.
So far, the vibration is still gone. It does it a little when the rpm's drop with the truck in gear at a stop. It idles at about 650k when this happens, so I'm not worried about it in these circumstances. At normal idle, it's just fine now.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rough Running and Rough Idle | b18vteceg | 86-95 Trucks & 4Runners | 13 | 12-28-2008 08:51 AM |
| Hard starting, rough idle problem | WesternViking | 86-95 Trucks & 4Runners | 0 | 11-22-2006 10:40 PM |
| 90 3.0 rough idle, bouncing idle, rich condition | Chuki | 86-95 Trucks & 4Runners | 1 | 11-04-2006 03:57 PM |
| another rough idle problem | RedNeckRunner | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 10-09-2005 03:53 PM |
| help! rough idle type problem | wxxyz | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 10-02-2003 10:19 PM |
