ring and pinion and other questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-11-2004, 03:02 AM   #1 (permalink)
outdoorfever's Avatar
Send a message via AIM to outdoorfever
Hey Guys. I was on all pros website tonight and noticed they had Hypinion R&P Gears. What exactly is Ring and Pinion Gears? It says '4.88 or 5.29 reverse cut gears direct from the original equipment supplier for Toyota' What does that mean? Are these like regular gears? I was looking for Gears for my truck that came with 4.10's so is this what I would need? What am I looking for as far as Gears are concerned? Be specific! Thanks in advance
__________________
-Kyle
Forasmuch then as Christ hath suffered for us in the flesh, arm yourselves likewise with the same mind: for he that hath suffered in the flesh hath ceased from sin; That he no longer should live the rest of his time in the flesh to the lusts of men, but to the will of God.
GOD IS A CONSUMING FIRE!!
outdoorfever is offline
Old 08-11-2004, 11:07 AM   #2 (permalink)
Flamedx4's Avatar
These (pic below) are ring and pinion gears. It's what you have in your axles that make the tires go... "Original Equipment Supplier" (commonly called the OEM) means the outfit that actually manufacturers and supplies various individual parts and assemblies to the vehicle manufacturers.
You might want to use the handy Search feature on this board, and use Google or your search engine of choice. There is more information than you ever wanted to know readily available. Also, look at things like lockers, limited slips, etc. Start here: http://www.reiderracing.com/ Explore the site, they provide a lot of useful info.
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil
Flamedx4 is offline
Old 08-11-2004, 01:06 PM   #3 (permalink)
mt_goat's Avatar
Quote:
Well I'm not sure, but I think the reverse cut gears are for someone who has done an SAS and is using a rear third member in the front. The high pinion gears are for high pinion 3rd members, which give more ground clearance and less drive line angle, not sure what application you can use them on, but I'm pretty sure you don't have one. Do you need new gears or a different gear ratio or both? I forget Kyle, do you have a 5-speed or auto? What size tires are you going to put on?
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 08-11-2004, 01:43 PM   #4 (permalink)
kyle_22r's Avatar
nope, reverse cut gears are for the high pinion third. they don't spin the opposite direction contrary to a lot of people's beliefs. ring and pinions have a "coast" side and a "drive" side of each tooth. on a typical front axle, you're running on the coast side of the gear when going forward, which is about 30% weaker than running on the drive side of the gear. a high pinion gearset in the front reverses this, the gears are cut with the coast and drive side specially designed to run in a front axle.
all rear axles and front axles from minis use standard cut gears from the factory, i believe tacos have a high pinion 7.5 in the front. fj80 land cruisers use a high pinion 8" in the front, which can be swapped into the front of a solid axle truck
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 08-11-2004, 02:49 PM   #5 (permalink)
lol so are these ok to buy? I am still kinda confused...
Dale: I have 31 inch tires right now. That was an upgrade 3 yrs ago from 27 inch stock tires. I looked on the door for my sticker that would tell me the normal gear ratio, but I am almost for certain its 4.10. I just changed my spark plugs and am still getting the same kind of mileage so I figured I would put in some new gears not only to help with mileage but for when I am off road as well. btw, I have an auto and have been reading that with auto's you need to go higher ratio since the power is different.
__________________
-Kyle
Old 08-11-2004, 04:47 PM   #6 (permalink)
Flamedx4's Avatar
[quote=outdoorfever]lol so are these ok to buy? I am still kinda confused...
Just buy them from a reputable shop (obviously you'll be having them installed - just let them worry about it) and they'll be sure to sell you the correct gears. Even if you feel strongly enough to specify a certain brand of gears, that's all you have to do. They'll get them and make sure they order what fits.
__________________
Flamedx4 is offline
Old 08-11-2004, 04:57 PM   #7 (permalink)
cool, thanks
__________________
-Kyle
Old 08-11-2004, 06:49 PM   #8 (permalink)
mt_goat's Avatar
Kyle_22r, thanks for seting me straight on that. I learned something.
__________________
~Dale~
mt_goat is offline
Old 08-11-2004, 07:07 PM   #9 (permalink)
mt_goat's Avatar
Kyle (in Tulsa), Toyota engineers decided that the best gear ratio for 31" tires with an auto tranny was 4.88:1. I know because that's what mine came with from the factory. I thought from the very beginning that the Toyota engineers were mistaken however, because my new truck (in 1993) couldn't pull a slight incline in OD (4th gear) and would drop itself down into 3rd gear and scream at about 4500 rpms all the way up the incline.
I think that 5.29:1 would be great with 31 inch tires and the auto tranny, and is liveable with 33 inch tires, but just barely. The only time you may not be happy with 5.29 gears and 31's is if you are going with a strong tail wind or down hill or both and have a speed limit of about 80 miles per hour with the traffic flow doing about 85-90 miles per hour.
Don't expect the gear change to make much difference in MPG though. I have kept track of my mileage at EVERY fill-up since 1993 and tried 4.88 gears with 31's and 33's, 5.71 gears with 33's, and 5.29 gears with 33's. And the MPG remained about constant through it all.
I'm running US Gears and I got them in Tulsa.
__________________
~Dale~
mt_goat is offline
Old 08-11-2004, 07:44 PM   #10 (permalink)
Thank you Flamed, Dale and Kyle for the information. I will PM any one of you if i have anymore questions. thanks again, Kyle
__________________
-Kyle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Ring and pinion help? b82ta3 General Vehicle Related Topics (Non Year Related) 8 07-02-2007 08:17 PM
Replacing Ring and Pinion scenarioL113 86-95 Trucks & 4Runners 4 06-03-2007 09:47 PM
Ring & Pinion help Blizzard 95.5-2004 Tacomas & 96-2002 4Runners 13 01-26-2005 03:12 PM
Ring and Pinion...Is more better? Denk Offroad Tech 5 10-21-2004 04:14 PM
ring and pinion toy4fun 95.5-2004 Tacomas & 96-2002 4Runners 15 10-09-2003 01:34 PM
2009 InternetBrands, Inc.
