Old 04-21-2016, 12:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Steering & Suspension Guides
Print Wikipost
Replacing upper ball joint. What else should I replace while under there?
Old 04-20-2011, 05:33 AM
Up&Down's Avatar
But does the steering wheel being off center indicate I need a new alignment?
I didn't mess with the tie rod ends. I just checked them and they were fine so there was no movement of those parts. I only replaced all ball joints and sway bar bushings and links.
Should I just take the steering wheel off and adjust it to center? I don't want to pay for an alignment if I don't need one. The truck rides perfect after the bj replacement. No change from previous ride performance.
Why would the steering wheel be off center after replacing ball joints and sway bar bushings/links?
Thanks for help on this.
Old 04-30-2011, 10:57 AM
Up&Down's Avatar
Went to the alignment shop. It did need an alignment. So the steering wheel off center was caused by toe change. Thanks to all who urged me to get an alignment instead of centering the steering wheel.
sandyota
02-04-2021 11:16 AM
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
rushw
07-18-2015 01:46 PM
Quick Reply: Replacing upper ball joint. What else should I replace while under there?
