Replacing the Starter
On my 96 4runner, I'm trying to get the starter out, which is the easiest? Dropping some of the lower exhaust? Or removing the exhaust header above it? I already got the tranny dip stick funnel out of the way. Thanks in advance!
Pete
Pete
a quick search will link you to an awesome write up....
ill do it for you
https://www.yotatech.com/~corey/tech...r/haveblue.htm
ill do it for you
ill do it for you
ill do it for you
Anyways, I figured out a way to do it without removing any exhaust at all, I got it through the wheel well.
Pete
All the links and info you could ever need including the write-up that fireteacher showed you... https://www.yotatech.com/forums/f2/4runner-starter-remove-removing-removal-replace-replacing-contacts-tips-how-89042/
I keyed mine down the bottom by the stabilizer bar. Or, I should say my friend got it out with his smaller hands that way. Remined me of changing a alternator in a 89 integra.
TURBOrunnerNM
07-22-2015 11:01 AM
ZONAYODA
07-13-2015 07:17 PM
