replacing shocks on a 3rd gen
so the 4runner has 117k on it with stock shocks, a 3" revtek and 2" 4crawler lift wth 33" maxxis mudders on it. at highway speeds theres a pretty big vibration problem, and im almost positive its due to the shocks.
the question arises as to which shocks to put in. as ive read on here, and looked around at stores, i think theres a few choices ive narrowed it to:
-bilsteins
-ome
the ? is for anything anyone here suggests. ride comfort isnt an issue; i do wheel it quite often, so its seeing a good amount of the offroad (lots of trails with hills and testing the suspension quite a bit). so obviously im looking for something very strong and durable for offroad. are there any shocks that can give me any more lift than what ive got? price isnt really an object. thanks for any input.
-bilsteins
-ome
Originally Posted by northfacer581
ive got a revtek 3" suspension lift...is there any way to gain more lift out of it with ome setup?
get a body lift from 4crawler.com - 1", 1.5", 2"...
I really like my Bilstein 5150 resivoir shocks. But then again those take some very minor modifications to install.
For bolt on shocks, the Old Man Emu seem to be the best and here is why. The front shock has a huge massive shaft like the Sway-A-Way or other high end coil-overs. The rear shock is the longest you can run without destroying your rear sway bar or completely impacting your gas tank on full drivers side stuff.
FWIW, the HD OME shocks are softer than your stock shocks, so what ever you do, get the Heavy Duty models, they are not really heavy duty in the sence you would think.
Originally Posted by bamachem
no, and w/ the IFS, you don't want to go any higher.
well i think im just going to order the ome shocks front and rear. up front im going to go with the n91s and in the back the n86. hopefully it will be an easy install.
the guys at http://www.wheelersoffroad.com are good people to work with and have good pricing...
06-01-2021 01:51 PM
tpd143
07-07-2015 09:06 AM
Steezy96yota
07-06-2015 10:00 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
