Replacing rotors
Old 01-12-2004, 11:13 AM
L33T35T 4Runner's Avatar
Replacing rotors
how hard is it to replace the rotors of a 95 4runner? mine are warped beyond recognition and i figured i'll just replace them.
how hard is it to do with a basic set of tools?
Old 01-12-2004, 11:19 AM
CTB
CTB's Avatar
It isn't too bad, but you need a pretty decent set of tools. I believe there is a write-up on here for it. If not, let me know, and I'll get into the specifics.
Old 01-12-2004, 11:30 AM
just found this writeup http://www.4x4wire.com/toyota/4Runne...enance/brakes/ it looks like you just pull them off once you remove the caliper
Old 01-12-2004, 11:41 AM
Guest
4RUNR's Avatar
How hard? All depends on how many bolts are rusted, how many will be a PITA to take out, how many would break off, and how many would want to re-drill and tap
Old 01-12-2004, 11:47 AM
MTL_4runner's Avatar
They come off pretty easy.
Quick hit with a deadblow mallet helps the process.
Old 01-12-2004, 11:52 AM
CTB
CTB's Avatar
Not quite that easy fellas....
2nd Gen and 3rd Gen have different rotor setups. Ours are bolted to the hubs, so they require quite a bit more work to remove and replace.
Old 01-12-2004, 12:22 PM
Robinhood150's Avatar
Don't forget to buy the 54mm socket before you start working on it.
Old 01-12-2004, 08:41 PM
whump
Old 01-12-2004, 09:10 PM
Mike Murrell's Avatar
Repack wheel bearings while you're there.
I'm not familiar with your model, but in most cases a fish scale may be used to set the preload on the wheel bearings. These can be purchased at Wal-Mart or sporting goods stores. You pull with it once you've tightened the wheel bearing to where you think it should be. If the reload calls for 3 lbs., the wheel should start to move once you've applied enough pressure to get it to 3 lbs. on the scale. This test is done with the caliper removed.
This approach helps to ensure that you do not over-tighten the wheel bearings.
Old 01-12-2004, 09:32 PM
AgRunner06's Avatar
Post
I just followed the instructions on 4x4wire and haven't had a problem yet. You will need the 54mm or 2 1/8" socket and a torque wrench to do the job. Also use some PB Blaster. A quick tip, mount the rotor and hub to the wheel when you try to seperate the two. You should also get two new grease seals. They are kinda a PITA to remove but you can do it with a flathead and a hammer. Just BE CAREFUL.
I have a long post somewhere around here about it.
Check out these threads.
https://www.yotatech.com/forums/show...4runner+rotors
https://www.yotatech.com/forums/show...rs+manual+hubs
If you need anymore help feel free to ask.
smthwsn357
12-04-2023 02:08 AM
sandyota
02-04-2021 11:16 AM
Sleaker
08-26-2020 06:03 AM
msane99
07-11-2015 08:08 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: Replacing rotors
