Replacing headlight bulbs
Old 10-07-2006, 02:56 PM
darkglass's Avatar
Just got a pair of the sylvania 9003's Super brite bulbs. However, something weird is going on. One is bright as it should be..and the other is dull. I replaced the dull one and still the same problem. Then, I checked the fuse box and swapped the fuses... ala now the the dull one is bright and the other side is dull. Soooooooo... I changed the fuse... still the same problem. I am clueless about this. There is a larger fuse of sorts called "head" in the box...could that be the problem?
Old 10-07-2006, 03:00 PM
keithguts's Avatar
Did you try putting back in the bolbs that you took out to see it they have a problem. Not sure about the fuse marked "HEAD" sorry
Old 10-07-2006, 03:03 PM
darkglass's Avatar
the original stock bulbs worked fine. Unless, the problem occurred durring changing to the new super brites... I dont know.
Old 10-07-2006, 03:06 PM
keithguts's Avatar
If the old ones work fine, then I woul say it is a problem with the new bolbs. If the old ones work ok still, then I would also say that it has nothing to do with the fuses. I'm sure somone will come along with the answer. Sorry I wish I could be of more help.
Keith
Old 10-07-2006, 03:09 PM
darkglass's Avatar
thanks anyways keith. These bulbs are recommended by the manufacturer for Toyota 4runner. I got them at advance auto parts...but, they dont have a clue either about whats going on.
here is the sylvania links:
http://www.sylvania.com/ConsumerProd...r/ProductLine/
http://www.sylvaniaautocatalog.com/s...%20ST,%20%20ST
Old 10-07-2006, 03:37 PM
Elton's Avatar
take them back and get a different set
Old 10-07-2006, 03:42 PM
Localmotion's Avatar
Silverstars are not the OE replacement. They are the bling replacement for the headlamps. If the bulbs you got have a blue tint to them, you have lost usuable light from what I recall.
www.danielsternlighting.com
Test your wires with a volt meter and see if you are losing current.
Old 10-07-2006, 03:43 PM
Elton's Avatar
well he said super bright bulbs im thinking one is pulling to much current
Old 10-07-2006, 03:53 PM
darkglass's Avatar
I think that is it. Once again these bulbs are recommended for replacement. Could this be a battery issue?
Old 10-08-2006, 07:48 AM
Ironmike4x4's Avatar
I had the exact problem.... Check the bulb itself and make sure it isn't cracked anywhere on the prongs. Mine was and I kept blowing fuses after awhile. High resistance = dimmer lights. What's funny is that I DID swap fuses and the same thing happened? I never could figure that out.
Old 10-08-2006, 03:07 PM
darkglass's Avatar
Mike,
Unless lightening strikes twice... I did replace the bulb in question. Yet, still the same thing. Maybe, I am not getting good conncection from the harness connector.
btw: thanks for the reply.. I dont feel so alone anymore.
Old 10-08-2006, 03:41 PM
fireteacher's Avatar
i dont think you said if you put the old ones back in or not. i doubt it would be your harness if the old ones were working fine UNLESS you pulled em out by the wires.....come on...fess up!
at least try the old ones again!
Old 10-08-2006, 03:47 PM
also, it wouldnt hurt to spray some electrical contact cleaner in their, if you wheel, could be dirty!
Old 10-09-2006, 07:12 AM
darkglass's Avatar
Problem solved... I think. I replaced one of the headlight 10a fuses with a 15 and now both headlights are burning bright as they should. Could this cause a problem using a higher amp fuse?
Old 10-09-2006, 04:49 PM
I don't recommend putting a higher amp fuse. If the amps are higher than what the wires are rated for and you have a short to ground then either you have a fire or some burnt wires. I'm thinking now you may need to upgrade the wiring harness. I don't know anything about it, but I'm sure others can tell you about Roger Brown's wiring harness upgrade kit. In fact you might want to PM him about your problem. He would probably better tell you what is going on. Roger is a genius
Old 10-10-2006, 04:27 AM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
Originally Posted by Ironmike4x4
I don't recommend putting a higher amp fuse. If the amps are higher than what the wires are rated for and you have a short to ground then either you have a fire or some burnt wires...
Ditto what Ironmike said. That's asking for trouble...
Old 10-10-2006, 06:39 AM
gregbreakseverything's Avatar
Ditto again
Old 10-10-2006, 03:14 PM
surf4runner's Avatar
ditto X3, but a higher amp fuse should not cause what he is talking about, its a safety feature, a 10A and a 15A should both let 10A flow w/o causing a voltage drop.
09-04-2015 09:27 AM
rushw
07-18-2015 01:46 PM
1994toyota
07-17-2015 03:03 AM
icentropy
07-14-2015 10:23 AM
madxman21
07-09-2015 10:26 AM
Quick Reply: Replacing headlight bulbs
