YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 05-02-2010, 03:27 PM   #1 (permalink)
Personal Sales Rating: (0)
Ritzy4Runner's Avatar
Replacing 4Runner horns with American Car Horns
Replacing the 4Runner Horn
Another in my on going series of "Mods for Dummies". This one will be installing a standard 2 note horn into a Gen 3 4runner.
Locate a suitable donor vehicle. I choose a 1999 Cadillac Deville. These horns were located behind the right side headlight. I was able to get both flutes and the harness for each horn. These are two wire horns (green & black) so using them in a 4runner is really simple once you see the schematic.
Before we begin,
Disclaimer: This write up is for educational purposes only. Any use or application of this procedure is done so at the risk of the installer/owner. The author and YotaTech are not responsible for any modifications done to any vehicle using these or any other related procedures contained in this write up. Descriptions and photographs are the sole property and copyright of the author ritzy4runner and may not be copied or distributed without written consent. Links to this article may be allowed but are protected by all US copyrights. Use of specific products along with any photographs of such items remains the copyrighted property of the copyright holder and is not an endorsement of any specific company or items.
Basic hand tools are required as well as a basic understanding of a 12vdc negative ground system.
Tools:
-10 mm socket/wrench
-12 mm socket/wrench
-3/8 drive ratchet handle
-3/8 drive 3” extension
-Diagonal cutters
-Wire strippers
-Wire connector crimper
-File or bench grinder
-Lineman pliers
-3/8” drill
-5/16t” drill bit
-2 - loop end lugs
-2 – Flat male connectors
Material:
-Set of dual note horns - two wire negative ground. I recommend metal body flutes for deeper tones. Most high end GM vehicles will have these. Be sure to get the flutes from the same vehicle so you don’t have two high/low horns
-Harness for horns
This is the basic wiring schematic for the Gen 3 4runner horn;
Click the image to open in full size.
Begin with selecting the horns that we will install. 1999 Cadillac Deville
Starting with the right side horn, using a 10 mm wrench/socket, remove the attaching bolt.
Grasp the connector at the top and pressing the tab in; pull the connector free of the horn.
Using a 10 mm socket, remove the right side hood latch holding bolt.
There are two horn flutes. The one we will mount first will be the horn that has an integrated threaded nut in the flange. The horn with the blind nut clip will be installed on the left side of radiator support.
Using the ball peen hammer, flatten the flange tang.
Click the image to open in full size. Click the image to open in full size.
Using the drill and 5/16” drill bit drill out the threads in the flange nut.
Using either a flat mill bastard file or bench grinder, remove the remaining shoulder of the flange threaded nut so the flange is flat.
Grasp the tang with the lineman or other suitable heavy duty pliers. Using an up-down motion break off the tang.
File down the end of the flange by rounding the end.
Install the Loop end connector to the black (ground wire) wire of the harness.
Install the flat male tip connector to the green wire.
Attach the horn harness to the horn.
From the right side of the radiator support, slip the horn down inside the space between the radiator and the grill working over to the hood latch hold down
Press the A/C tubing back into its clip on the radiator center support.
Tighten the hood latch bolt securely but do not over tighten. Ensure the horn flute is situated so as not to touch either the support or the A/C tubing.
Connect the flat tip male connector from the horn harness to the OEM connector for the right side horn.
Route the ground loop connector under the A/C tubing and up to the right side OEM horn location. Reinstall the horn bolt. I used the OEM horn as the washer as it would provide a solid mount and contact point for the ground.
The right side horn is now installed.
Prepare the second horn flute as follows; the second flute uses a clip blind nut. Remove this clip.
Attach the loop end connector to the ground (black) wire.
Attach the flat male end connector to the positive (green) wire.
Attach the harness to the second horn.
Remove the left side horn.
Squeeze the connector as you did for the right side horn connector and pull the connector free from the horn.
Install the new horn in the left horn location. Place the loop end connector between the radiator support and the horn flange, and then tighten.
Position the flange so that the flange tang points upward. Using the ball peen hammer, tap the flange over to provide for solid placement of the horn.
Connect the flat blade connector (green wire) to the OEM horn connector.
If it is desired, you may tie back the harnesses but if the harness were trimmed during installation this will not be necessary.
The horns are now installed. Enjoy!
Follow this link to hear the horns, 4runner stock OEM Gen 3 horn and the installed Cadillac dual flute horns.
http://www.youtube.com/watch?v=TmYrNkx2SdQ
__________________
98 4Runner SR5 "Limited" 3.4 V6, Automatic-Field Monitor Unit, Auto Dimming Mirror w/Compass & Temp, Reverse Silver gauges, JDM tail lights w/LEDs, Corner Light turn signal mod, Center Console Cup holder Mod w/ LEDs, auxillary fuse panel, Land Cruiser Hydraulic hood lifts, Engine Bay lites, Dual interior dome lights, Overhead DVD player, Taurus Fan mod w/ indicators, 2000 headlight mod, '00 Sport grill ......
2000 Celica GT, 'SydJUce'
1990 4runner
"Life is a journey, don't forget to pack."
Ritzy4Runner is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 05-02-2010, 03:42 PM   #2 (permalink)
Elton's Avatar
elton hostler
Send a message via AIM to Elton Send a message via MSN to Elton
nice write up .... i used a set of ford superduty horns and a stebel compact air horn its real loud
__________________
07 Tundra d-cab limited 5.7L 4x4 was my moms r.i.p 3/19/11
98 4runner SR5 3.4L 5spd 4x4 E-Locker sold 10-2-11
91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06
97 honda civic lx 4dr ls vtec
Elton is offline
Old 05-02-2010, 04:07 PM   #3 (permalink)
Eltons got the horn I want.Horns are for making dangerously stupid people on the road crap in there pants.IMO...I.E.people texting while driving,my favorite-people driving in 2 lanes,driving while stupid is very common.
Matt4Running is offline
Old 05-02-2010, 04:20 PM   #4 (permalink)
OEM Nazi
Personal Sales Rating: (17)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Option two: Find a set off a lexus. They are plug and play
Nice writeup, very exact and detailed!
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by BigBluePile View Post
Hmmm, dunno. Ask the oem Nazi DC.
Quote:
Originally Posted by kiyobrown View Post
I'll cut you.
DeathCougar is offline
Old 05-02-2010, 08:10 PM   #5 (permalink)
Threadstarter [OP]
Oh Sure! NOW you tell me!
I'll have to watch out for a set next time I am out. Really do like Lexus. And THANKS DC!
Decided to go with these horns as they can be found quite easily and they should be pretty easy for just about anyone looking to get a more solid sound from their horns.
__________________
1990 4runner
Old 05-03-2010, 06:34 PM   #6 (permalink)
desertcamper67's Avatar
Very nice write up. Gonna check Lexus's next time I'm at the boneyard.
__________________
'85 4Runner totaled and brought back 22RE-C 5spd 4.88's, Rear IFS axle with Detroit Locker and Tru Trac up front
Doug Thorley Header and LC Engineering Cam, K+N, Downey 3 inch leaves and Rubicon shackles with Pro Comp shocks
32x11.5-15 BFG AT's
Quote:
Do I like what I have-Yes.
Does it sound good-Yes.
Does it intimidate Ricers-Oh yeah.
Does it perform-Yes.
desertcamper67 is offline
Old 05-03-2010, 10:45 PM   #7 (permalink)
Ron Helmuth's Avatar
I have Crown Vic horns but am still always on the lookout for the Ultimate...thanks DC for the Lexus suggestion.
I had a Ford truck horn for awhile in general they are still too high pitched- I want something with some low end rumble.
Idiot the other day was doing the slow speed drift from left lane into right. About every 30 seconds it would repeat... Could not see the drivers head, caught up at a light and it was an elderly lady who no longer should be driving methinks...
Outstanding detail just like all the Ritz writeups.
__________________
99 4Runner SR5 4wd 3.4/5 spd-
Factory Locker
O/M/Emu springs- 881 fronts/890 rears
O/M/E shocks- N91s fr/N86 rr
All Pro Off Road welded on sliders
ARB"Taco"bumper/Hella 500s & side markers
Redline Tuning hood struts/Bushwackers
2" 4crawler.com body lift
all my Yota photos are over on Facebook now
http://www.facebook.com/album.php?ai...5&l=5795132731
Ron Helmuth is offline
Old 05-04-2010, 12:04 AM   #8 (permalink)
theferg's Avatar
Option three: find a set off an 01-02 4Runner or an 01-04 Tacoma. Also plug and play and have that "American" sound.
Funny though, I've done just the opposite...I pulled the "American" sounding horns off my '02 and chucked them right in the trash and installed some LandCruiser 80 series horns (also plug and play) to get me that nice Toyota sound I've known and loved for many many years.
-Ferg-
__________________
Ferg | TLCA 12162
80 Series Electric Lockers into an FJ60
theferg is offline
Old 05-25-2010, 09:42 AM   #9 (permalink)
Threadstarter [OP]
I have since "modified" my horns, seems one of the tones died ... hey it was a used part, but anyway, decided to go with the twin horns from 91 and 92 Lincoln Continental. They use two tones, are grounded via the mounting bolt and both horns HI & LO are tied together so you end up with a single wire to attach. I decided to give a pair of these a try as they only needed one wire to operate both notes so I figured what the heck? Twice the horns should be a bit louder then just the one pair ... WOW
Needles to say I had to do a bit of hanger mounting bending but after flattening them out, I ended up mounting them in the same locaitons as I had the single horn notes from the Caddy. I'll try to update the write up to reflect some of the changes. As for cost. less then $5 for both sets!
__________________
1990 4runner
Old 05-30-2010, 03:52 AM   #10 (permalink)
terminator's Avatar
Send a message via AIM to terminator
Any particular Lexus model or year?
terminator is offline
Old 05-30-2010, 04:15 AM   #11 (permalink)
Personal Sales Rating: (1)
space-junk's Avatar
another option is the Scion tC horns... huch louder and deeper than the stock one... can also be found on camrys and avalons...
__________________
1995.5 Tacoma SX
Build Thread - a few mods
1987 Turbo 4Runner
Build Thread
LCE*Crackaway Racing Engines*Hi Lift*175K
Rebuild in progress...
1990 4Runner SR5 - Sold :(
space-junk is offline
Old 05-30-2010, 04:44 AM   #12 (permalink)
xxxtreme22r's Avatar
I installed a dual note twin horn setup from an E34 BMW. $5.00 for the set at a junk yard. I got to get 92Toy to make a video for me as someone around here lost our camera.
__________________
3rd Annual YOTATECH Rausch Creek Run and 2012 EC4RJ Pennsylvania
Build Thread
BMW Thread
87 P/U 4X 5sp Weber Downey Hdr 2.25 Exh EB 268
xxxtreme22r is offline
Old 05-30-2010, 08:32 AM   #13 (permalink)
OEM Nazi
Staff
Quote:
Right off the top of my head, I am not 100% sure. Same year stuff usually works, and I think Toyota/Lexus redesigned their horns in 92 or 93 which will match the later year stuff.
__________________
I'll cut you.
Old 12-17-2011, 04:46 AM   #14 (permalink)
terminator's Avatar
I forgot about this mod until we had a guy come into our shop and wanted to change out the horns on his newer Caddy for the kind that was stock in his 91 Deville.
Originally I had purchased some JY Lexus horns from I think either an ES300 or LS400 and didn't notice anything different.
Then the above mentioned Caddilac guy came in and reminded me of the Caddy horn mod. I pulled a pair from a 91 Deville, modded the brackets similar to the write up above and installed them and DAYUM what a difference!!!
The Cadillac horn mod is one of the very easiest and cheapest to do and I highly recommend it to anybody not wanting air horns.
Old 01-08-2012, 04:14 AM   #15 (permalink)
uncleblues's Avatar
trying this today with a pair of horns from a Yukon, wish me luck
uncleblues is offline
Old 01-08-2012, 05:16 AM   #16 (permalink)
Older RWD Cadillacs and Buicks have the sets of 4 horns, all different notes. Really gives it that full orchestral impact, with all the highs and lows.
Chevy's and Old's made do with only 2.
Jomoka is offline
Old 01-11-2012, 08:30 AM   #17 (permalink)
paddlenbike's Avatar
Nice. I'm a big fan of my Cadillac 4-note horns.
4 Caddys versus 2 Toyota horns:
You mounted yours the same way as mine; the A and F notes are in the stock location and the C and D notes are next to the battery:
They sound amazing.
http://www.youtube.com/watch?v=ljZWstarTsc
__________________
2000 4Runner SR5 V6 4WD | TRD SC | 5-speed | E-locker | Tundra/OME lift | Stubbs Sliders | | Click here for specs & pics
paddlenbike is offline
Old 07-31-2012, 09:27 AM   #18 (permalink)
theferg's Avatar
Anybody have their old horns laying around? I need another set of original "foreign" sounding horns for a new project. I am willing to trade my stock "American" sounding horns or pay a few $$.
-Ferg
__________________
Ferg | TLCA 12162
theferg is offline
Old 07-31-2012, 12:12 PM   #19 (permalink)
terminator's Avatar
I have my 96 4Runner horns still, cover a 12 pack of beer and shipping and they're yours.
Jason
Old 08-14-2012, 09:27 PM   #20 (permalink)
black_taco's Avatar
Send a message via MSN to black_taco
This is funny...I was browsing the local "you pull it" style salvage yard when I came across a Cadillac with the 4 horns. FWIW I think it was a 1994. I find it funny that someone else suffered American horn envy enough to perform the mods I have in mind. I still haven't mounted mine yet because I need to round off the tops of the metal brackets on the horns and wire everything up. The problem that I ran into was finding a place to fit all four of them to minimize the amount of wire I have running. I decided to sacrifice a little noise and mount them on top of the passenger wheel well. I ended up machining a post for them to mount to as you can see in the pics. The post is tapped on one end to accept a bolt that will pass though a hole already in the wheel well sheet metal of my 1996 Tacoma. The all thread allowed for adjustable placement to minimize interference with other engine bay components. Has anyone with a four horn setup felt the need to use a relay due to the higher amperage? I was leaning towards using a relay just to be safe.
20120814_194036 by xcmtb83, on Flickr
20120814_194132 by xcmtb83, on Flickr
black_taco is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
2010, 4runner, 98, american, auto, car, hilow, horn, horns, location, loud, replace, replacement, runner, sound
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
