| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Replacement Battery Options....
__________________
01' SR5 Sport Edition Performance: Deck Plate w/ Amsoil Filter, ISR Mod, Dynomax Super Turbo w/ Pacesetter Tip Exterior: Manik Brush Guard, Piaa 1000X, Piaa 540, OEM Skid Plate, Custom Sidemarkers, Clear Corners/Bumpers, H/L Alenzas, Thule Lappland Cargo Basket, Reverse Lamps, Silverstars Interior: Stereo System, Dakota Digital Gauges, Coleman Inverter, Speedhut Gauges http://community.webshots.com/user/phi1514 |
#2 (permalink) |
Why not hook up two batteries? Mike
__________________
2001 Tacoma SR5 4x4 , step side, 2.7 , extended cab, Auto. Mobile 1 syn 5w30 , Valvoline 75-90 syn in front and rear diffs and transfer case. Factory 16" wheels ,31" Wild Country TXR 265/75/R16, Aluminum Betterbuilt bed tool box, CB , 55W Halogen light mounted on tool box for back up, Elbow air box mod, 2 500 Hella running lights, Nissan Clinometers/Altimiter custom mounted on dash with red back lights.Red dome and mapp light. |
#3 (permalink) | |
Quote:
#4 (permalink) |
Well, I skimmed through Optimas website for a couple of minutes and I did not realize that the Blue Top was a marine battery. I found this thread on Yotatech that I'm going to read through it a little more in depth tomorrow....
http://www.yotatech.com/showthread.p...ghlight=Optima My question is are there any issues in using a marine battery in a truck? Do the Optimas recharge as quickly as a normal wet cell battery and will they run accessories (ie a TV) a lot longer than the stockie that's in there now? Matt
__________________
#5 (permalink) |
I definitely don't have the cash (or the time to install) two of them but I do remember seeing a guy on here with a sweet two battery setup.
Matt
__________________
#6 (permalink) | |
Quote:
#7 (permalink) | ||
Quote:
Quote:
quicker? hmmmm... dont know. your issue that you use the batt when the engine aint running. that is the reason to go dual batts. make the second batt a yellow or even the blue topper. your primary batt should not be touched when then engine is running and powering your aux equipment. but doing all this brings in all sorts of newer "problems"... may i suggest a gas powered generator?
__________________
leo d. stock 90 4runner |
#8 (permalink) |
Batt Caps are just capacitors I believe....they store voltage for a short time. I suspect that they are standard stiffening capacitors used similary in audio applications. I know that all capacitors that I know about are used to store voltage for very short periods. I don't know how they would store voltage for more than a few mins. If you have more info it would be appreciated.
Dual battery with isolator would seem to be the ideal solution to me. Or get a smaller TV. Actually an LCD TV would pull 1/3 the wattage. Good excuse to get one.Just my 2 cents.
__________________
2002 Stellar Blue 4Runner Sport Edition Cold Air Intake Magnaflow Exhaust Iridium Sparkplugs Kenwood KDC-MP628 Blaupunkt Separates in all of the doors Two RF P2002 amps Kenwood 12" Subwoofer My baby: Pics Last edited by DavidA; 07-18-2005 at 10:32 PM. |
#9 (permalink) |
I can get the yellow top from Batteries Plus here in Birmingham for $100 plus tax after my Southern Company employee discount. I think if I swap it out, I'm gonna go with the yellow instead of the blue. Thoughts?
Matt
__________________
#10 (permalink) |
Super Moderator-Sponsoring Member
Staff
To run dual batteries ain't cheap, but I got triple batteries, so it is $$$.
http://www.drawhorn.org/dual_batteries.htm You can just use the kit I got and run duals easy. Anybody who can tie their shoes can do it...easy installation. I wouldn't get a blue for cranking as that is a deep cycle marine battery and you might regret that this winter. Get a Red/Yellow Optima for your cranker and then a Yellow/Blue for your drainer. The system in the right mode won't let your dual drain your main battery. A well done dual batt system is well worth the extra money. You wouldn't want to miss those tailgate ballgames because you were a cheap now would you? ![]() I'll be glad to answer any particulars, but the Painless kit and the Optimas are the way to do it and do it right IMO.
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 89 4runner tailgate replacement options | slamigo | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 09-06-2007 01:14 PM |
| Siren replacement advice: What are my options? | rimpainter.com | Alarm Systems | 4 | 10-21-2006 09:45 PM |
| OEM leather replacement options? | HaveBlue | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 09-19-2006 04:32 PM |
| 22RE Replacement Options | FingerMan20 | 95.5-2004 Tacomas & 96-2002 4Runners | 18 | 07-11-2005 06:58 AM |
