Replace with 22re or 22rte?? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-27-2004, 06:00 PM   #1 (permalink)
Just bought an 86 4Runner. But it needs a new engine. Should I go turbo or not?
Pros and Cons would be appreciated. (And cost would be roughly the same.)
Thanks in advance.
blkntan is offline
Old 11-27-2004, 06:21 PM   #2 (permalink)
Flamedx4's Avatar
I vote Not.
First, where do figure to get a 22RET engine? There weren't many and the vast majority of them died years ago. Turbo parts are few and far between.
Do a few mods to the 22RE and you'll have a willing toquey little motor that will last a long long time.
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil
Flamedx4 is offline
Old 11-27-2004, 09:41 PM   #3 (permalink)
kyle_22r's Avatar
it's not that much more work to turn a 22RE into a 22RTE, but to do it right you're going to have to shell out some cash either way. the stock turbo toyota used is an expensive piece of junk.
if you want turbo, check this site: http://www.well.com/~mosk/
to do it right, you've got some work ahead of you...if you don't mind dropping a couple grand, you can also go for LC engineering's supercharger setup
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 11-27-2004, 11:20 PM   #4 (permalink)
mikedog's Avatar
For the couple of grand it's going to cost you for the weak powered 22RET swap, you'd be better off doing the Supra 7M-GTE swap. The power potential of the Supra engine will be significantly better. Just think about it this way, 230hp stock compared to 135hp stock.
In fact, I'm willing to bet that the Supra engine will be less expensive than doing a 22RET swap. You can find lots of used 7M-GTE engines floating around compared to relatively rare 22RET engine.
If you just desire the 22RET for the rarity aspect, then try getting a compete 22RET truck. It'll probably be cheaper in the long run. I used to see them pop up in the truck-trader every once in the while.
mikedog is offline
Old 11-27-2004, 11:58 PM   #5 (permalink)
Thanks for you input. I was debating a supra swap also, but wanted to know my options.
Anyone here do the Supra swap? How much will that cost and how more work would it be compared to a 22re?
blkntan is offline
Old 11-28-2004, 12:14 AM   #6 (permalink)
Nevermind.. after doing more research.. I think I'm just going to get a remanufactured 22re and then add some mods. Thanks again.
blkntan is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22RTE clutch/flywheel in 22RE setup???? Yoda General Vehicle Related Topics (Non Year Related) 8 04-12-2009 07:28 PM
22RTE to 22RE....how hard? Numbchux 86-95 Trucks & 4Runners 11 05-19-2007 10:26 PM
22RTE/22RE hybrid running. dcg9381 86-95 Trucks & 4Runners 34 12-19-2006 07:02 PM
dif. between 22re and 22rte Matt80539 86-95 Trucks & 4Runners 4 06-04-2006 07:37 PM
85 with 22RE, or 86 with 22RTE? CGuava 95.5-2004 Tacomas & 96-2002 4Runners 3 03-12-2003 02:27 PM
2009 InternetBrands, Inc.
