Remote rear window button
Old Aug 26, 2010 | 04:24 PM
ryani's Avatar
I recently camped a weekend in the 4 runner and it worked great except when you got hot or cold you had fumble through the front packed with stuff, find the key turn it on, hope the radio wasn't cranked find the rear window button and roll it up or down. Alot of hassle. I made something better.
I purchased a window universal switch from parts express for 10 bucks shipped, did a little wire tracing and Viola! I have window switch on the inside of the rear cargo hatch that you don't have to worry about the key.
I traced the wires off the key tumbler for the rear window. I hooked up the 3 wires up and cut a hole in the plastic cover.
Works great and a cheap mod too.
Here's a link to the pictures. http://picasaweb.google.com/ryan.ied...eat=directlink
Old Aug 26, 2010 | 04:51 PM
pwd's Avatar
pwd
Sounds great, do you have any photos?
Old Aug 26, 2010 | 05:25 PM
JWaldz's Avatar
Old Aug 26, 2010 | 07:09 PM
ryani's Avatar
I do have some pictures but it won't let me upload them. I have never had the problem before. I'll try again.
Updated above. Posted a link
Old Aug 26, 2010 | 08:04 PM
Kerby J's Avatar
a writeup as in which wires and such would nice
Old Aug 26, 2010 | 08:44 PM
JWaldz's Avatar
do you still not have to have the key turned? I'm interested in a wiring guide as well.
Old Aug 27, 2010 | 05:04 AM
ryani's Avatar
If you pull the plastic cover off the lift gate you will see a plastic control box.
There's three wires running from the back of the switch key barrel down to the blue control box.
One white and black one which is the ground. It would be your center post on the switch.
Then there is a dark green with a yellow stripe and dark green with a red stripe. These are your +12v. One is up and one is down. They are located on the blue box. One row in from the passenger side stacked on top of each other.
They go on the momentary part of the switch.
You don't have to have the key on at all. Thats what makes it so slick. It's paralleling the key switch on the outside of the lift gate.
Old Dec 28, 2010 | 10:29 AM
Gerdo's Avatar
I was just sitting here thinking about this exact mod. Sounds simple.
I'm putting this on my list.
Old Dec 30, 2010 | 02:48 PM
Ron Helmuth's Avatar
great idea ryani-dang you are one resourceful poster. I liked your input on the Unistrut cargo basket bracket mounting -copied that shamelessly and now this comes along.
Good to have you on here sir.
Old May 9, 2020 | 06:28 AM
Blurm's Avatar
5 Year Member
I was hoping someone may be able to provide some guidance on this mod.
I recently added the switch to the back and I cannot find the wire that triggers the window to roll up. ( Supposed to be green with red stripe but that wire doesn't work )
When I ground the green with a yellow it goes down no problem but .... I can't find the control wire that rolls it up.....
Any advice would be appreciated. My electrical experience is limited.
Old May 19, 2020 | 02:35 AM
Zcostilla's Avatar
Can you take a photo of the wires?
Old May 19, 2020 | 07:28 AM
Robert m's Avatar
Maybe this thread will help https://www.toyota-4runner.org/3rd-g...-pictures.html
Old May 25, 2020 | 12:18 PM
Blurm's Avatar
5 Year Member
https://photos.google.com/photo/AF1Q...311LgNnWEQgMOI
I hope this link works....and if so its a pretty good picture of the wiring
Old May 25, 2020 | 05:30 PM
Zcostilla's Avatar
I got a 404 not found
Old May 26, 2020 | 07:41 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
I get a gurgle sign in. Eff them. Keep searchin!
rattlewagon
Jul 30, 2010 03:48 PM
jaaydee
12
Apr 2, 2010 08:55 AM
thatton
Nov 16, 2009 01:42 PM
mbeck
Oct 21, 2004 07:03 AM
justinh
Aug 6, 2003 12:01 PM
