Rear Shock Bolt Thread Pitch?
Does anyone know what the lower bolt that attaches the rear shocks of a 1997 4runner thread pitch is? I need to get 12mmx30mm bolts, but I need to know if it's a 1.75, 1.5, or 1.25 thread pitch, whatever that means. Does anyone know? I'm needing this, because the rear limiting straps require a longer bolt to clear the lower edge of the shock.
Chris
Chris
OEM Bolt...
Take the bolt that you took out to a bolt supply place in your town, look it up in the yellow pages, and tell them that you need a longer one with the same pitch. They should be able to match it up and get you the one you need.
Hope this helps.
Brian
Hope this helps.
Brian
DOH!
Originally posted by ravencr
That's what I'm trying to prevent doing. I don't want to have to take the bolt out. I'm lazy!
Chris
Chris
Maybe you could find a detail of the shock assembly online somewhere by doing a search?
Hope you get it figured out!
Brian
Chris, I think it is a 1.25 but don't quote me on that.
You could get a metric thead gage at the store and match it up.
On most foreign cars the 1.25 is a coarse and 1.5 is a fine.
Maybe someone else can verify this.
i found this, it doesnt have a thread pitch, but it does tell you what to torque the shock bolts to
rear suspension
rear suspension
06-01-2021 01:51 PM
jon.r
07-11-2015 03:34 PM
icentropy
07-09-2015 02:12 PM
