Quick help needed: Rotors won't come off
Old Nov 22, 2004 | 06:52 PM
Pretacopower's Avatar
I'm replacing my rotors/pads tonight with a friend and my rotors won't slide off...are there any other bolts in the back that we don't see holding the thing on? Or do we just need to yank harder?
Thanks for any advice....this is my first time doing my own brakes
Old Nov 22, 2004 | 07:24 PM
AgRunner06's Avatar
I've never done rotors on a 2wd Toyota but my guess would be that if you have removed the nut that holds the rotor on then you should be able to pull it off. You might want to try tapping the back of the rotor with a hammer. That will probably pop it loose and it'll slide off.
Good Luck
:bounce2:
Old Nov 22, 2004 | 10:48 PM
Good Luck
:bounce2:
Yeah I went back out and gave it a few good whacks with the rubber mallet and off it went :pat:
Thanks for the reply though!
Old Nov 23, 2004 | 04:56 AM
There was probably a small rim or layer of rust where the hub and rotor come together (inside rim). Use a small wire brush or sand paper to get the rust off. Then coat each surface with anti-seize compound around the rim. This has prevented my rotors from sticking permantly. Or just take it as it is and remember to have fun banging on it with a large hammer each time.
On a side note - which pads did you use?? I replaced mine with the Performance Friction instead of OEM. Damn the dust that accumulates now. It is making my wife's Volvo look clean. They use super soft pads that generate unreal amounts of dust. I think I'm going back to OEM on the next trip.
Best of Luck
Andrew
Old Nov 23, 2004 | 07:24 PM
I used Hawk performance friction pads...too early to tell whether or not they're leaving a mess, though I'm LOVING the new stopping power I've got. :bounce2:
Powerslot rotors+Hawk Performance pads = good combo
Old Nov 25, 2004 | 06:50 AM
hypnotoad's Avatar
probably too late now, but on the rotor itself (not the braking surface) are threaded bolt holes - just find 2 of the right size bolts, and evenly insert them. They'll press it right off.
sandyota
Feb 4, 2021 11:16 AM
cars-guy
Aug 16, 2020 06:59 AM
Leviticus6432
Nov 20, 2015 05:06 PM
RobotMoose
Sep 2, 2015 05:53 AM
izzmee
Aug 17, 2015 10:20 AM
