Question about Sliders?
Old 10-26-2007, 11:14 AM
frodin1's Avatar
I was wondering if the Stubbs sliders require you to cut the pinch weld as required with the install of Trailgear sliders? I couldn't find any install info in referernce to the Stubbs sliders. I guess Sonoran is the only place selling them now.
Old 10-26-2007, 11:37 AM
waskillywabbit's Avatar
I have installed lots of sliders and never cut the pinch weld as IMO there is no need to do so.
Old 10-26-2007, 11:44 AM
wormhole's Avatar
What wabbit said is true. I have a set of stubbs on my 4runner and the pinch weld didn't need to notched. I order mine directly from Richard (if i remember his name right). Just tell him what length you want, if you have the factory fender flares and if you want the kick out.
Old 10-26-2007, 11:50 AM
mt_goat's Avatar
My Trail Gear sliders didn't require the pinch weld to be cut.
Old 10-26-2007, 11:57 AM
frodin1's Avatar
What's different between the ones for fender flares and ones that aren't?
Old 10-26-2007, 12:17 PM
Nate08's Avatar
I just installed mine...about 1/4-1/2" below the pinch weld. Didnt need to be cut.
Old 10-26-2007, 12:22 PM
wormhole's Avatar
Basically, just the length. The rear flares on mine had to be trimmed a bit to fit correctly. (I should do the front but they don't cause any problems).
Old 10-26-2007, 12:25 PM
frodin1's Avatar
That's what I thought. I was just looking into buying some off someone "marketplace" and I just wanted to make sure they'll fit properly. I think I'm going to pass. Good deal if your close to PA, on a pair of SKO's from Stubbs. Thanks for your help!
Old 10-26-2007, 01:02 PM
OSU4Runner's Avatar
Yea, definately make sure that when you do your install, they are at leat a 1/4'' below the pinch weld. They mounted mine flush with it, now they bash against the pinch weld when I hit bumps. Once I put my body lift on it'll go away, buts its really annoying
Old 10-26-2007, 04:41 PM
pmbazus's Avatar
Buy them from Stubbs Welding direct and you don't have to cut the pinch weld. These are Stubbs sliders on my 2004 Tacoma.
Old 10-26-2007, 04:43 PM
pmbazus's Avatar
http://www.stubbswelding.com/
Old 10-26-2007, 04:51 PM
fillsrunner4's Avatar
i cut the pinch weld on mine and i would do it again to any sliders i would install. i would because its easy to build the sliders stronger with the addition of a piece of flat bar welded to the frame for renforcement + gussets. its true you can do this without cutting out the pinch weld. i just think its that much stronger if you do it that way and can mount the tube a bit higher on the flat bar. than at the bottom of the frame. if that doesnt make sence ill post some pics tommorow to show you an example why i did
Old 10-26-2007, 05:01 PM
heres a quick right up on instalation for All Pro's sliders. cutting the weld is up to you but like i said before i would do it http://allprooffroad.com/index.php?o...ask=view&id=63
94ofCanada
08-14-2015 06:37 AM
nickbeauregard
12
08-07-2015 06:04 AM
priest16
15
08-06-2015 07:43 AM
Luvmeye22re
08-04-2015 03:53 PM
coryc85
07-06-2015 04:07 AM
Quick Reply: Question about Sliders?
