YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-21-2005, 10:47 AM   #1 (permalink)
Pulling a pop-up w/4runner
I have an 91 runner w/3.0, auto and I want to be able to tow a small pop-up camper to and from my wheelin distinations. I plan on running 35's, maybe 37's. What gears should I get? 4:88 or 5.29? Does anyone have any experience with this combo?
85badger is offline
Sponsored Links
To remove this ad, register today!
Old 02-21-2005, 11:01 AM   #2 (permalink)
ok, let me be more specific, I'm going to run 37's, with 5.29's, does the 3.0/auto have to hp to pull a small pop-up at highway speeds?
85badger is offline
Old 02-21-2005, 11:09 AM   #3 (permalink)
turboale's Avatar
Send a message via AIM to turboale
where are you? Do you live where its flat or will it be constant up/dn/up/dn? The only really way to tell is to go try it. I would definitely invest in a tranny cooler either way. Cheap insurance. I don't have the 3.0 so I'll leave better educated guess to others, though I have seen a 2nd gen with a SAS and at least 35s if not 37s pull a MasterCraft Xstar ski boat, and that was w/o a re-gear. It was not quick by any means, but it did it.
__________________
--Austin
06 M45 Sport - Beauty
96 4Runner - The Beast
turboale is offline
Old 02-21-2005, 11:15 AM   #4 (permalink)
Well, I'm here in flatter than flat Kansas, but I wheel in CO and some in OK, which both have up/dn/up/dn. Tranny cooler is a must, good idea.
85badger is offline
Old 02-21-2005, 11:22 AM   #5 (permalink)
turboale's Avatar
Not the cheapest wroute but if you had some extra money you wanted to spend on your truck (ha right) I would say get another set of wheels/tires. Then you can have a street set and a trail set. Its not like your throwing the money away, they will pay for themselves over time with all the money you will save on gas. Then you also have a rig thats not a complete pig around town. Just get some 33s on your stock rims and get some steelies cheap and put the 35/7s on those. Just thinking out loud... That is what I was going to do until I jumped into this supercharging thing...
__________________
--Austin
turboale is offline
Old 02-21-2005, 11:47 AM   #6 (permalink)
SD70MAC's Avatar
It also depends on the weight of the trailer. My parents used to have a 2001 Coleman pop-up that weighed about 3500 lbs. I know my 3.0 wouldn't pull that thing period! That's why they used a Tahoe. Of course, mine is in need of engine and tranny work too... Like the others said, just try it and see how it does.
__________________
FOR SALE: 89 4Runner - 3.0. BFG All-Terrain T/As
D&RGW - "Mainline Through The Rockies, Not Around Them"
SD70MAC is offline
Old 02-21-2005, 12:05 PM   #7 (permalink)
I have a newer engine in it approx. 45K on it. Runs good, I use to have a 98 see doo xp, pulled it just fine when it was stock.
85badger is offline
Old 02-21-2005, 04:41 PM   #8 (permalink)
Flamedx4's Avatar
Quote:
HOLYCoW! I have an Apache, which is all fiberglass and I thought it was heavy at 1300 lbs (probably close to 2000 with all my stuff and the little boat on the roof.) Which my 22RE/5sp with 33s/4:88s pulled just fine, although I did know it was there. We got some steep mountains in the Pacific Northwest. Heck, in Kansas ya could pull it with a bicycle...
But 90% of the time, the point of taking the trailer was to go to a farther away wheelin spot, so different tires is not a good solution.
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil
Flamedx4 is offline
Old 02-21-2005, 04:50 PM   #9 (permalink)
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
Send a message via AIM to Rick F. Send a message via Yahoo to Rick F.
I pulled a 2800 lb. Jayco popup with my '90 3.0, manual tranny with stock 31 x 10.5 x 15's for about 4 years. I typically had it full of stuff plus the kids & wife in the truck. You didn't want to be behind me on any hills in no passing zones, but it did fine otherwise. Most campers are lighter than my Jayco, but I still had some difficulty pulling an 1800 lb. boat up hill. I'd be leary if you have any steep, long grades to climb.
__________________
'00 SR5, Desert Dune: 4" Deckplate, Amsoil TS-115, Bilsteins, Brembo rotors w/Performance Friction pads, Fiam Highway Blasters, Sylvania Silverstars, Hella Micro DE Fog Lights w/Hella Yellow Star Lamps
'08 Sport, Salsa Red: bone stock (for now...)
Rick F. is offline
Old 02-21-2005, 05:05 PM   #10 (permalink)
dragr1's Avatar
Quote:
With 5.29's and a tranny cooler you should be good to go, oh and a massive hitch drop-probably a foot with 37's!
If you don't have a popup, I've got one for sale that only weighs 1500 pounds empty.:
http://www.yotatech.com/showthread.php?t=51123
__________________
1985 4Runner Dual e-lockers, dual cases, yada yada
'00 Suburban 2500 4x4
'07 Tacoma Double Cab 4wd TRD
'02 Lexus IS300
1991 Tiffin Allegro 31' Class A
dragr1 is offline
Old 02-22-2005, 05:42 AM   #11 (permalink)
yeah, I checked out your camper....nice one!! I'm only in the "make up my mind stage" on the truck, haven't touched it yet, still stock. So I'll have to wait on the camper. Glad to hear that other people have done this. Thanks for the input.
85badger is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Pics of my 4runner with marlin bumper pulling 3500lbs trailer Red3.slow 86-95 Trucks & 4Runners 15 06-26-2007 02:39 PM
Brakes Pulling To Passenger Side, 2nd gen 4runner jsnby 86-95 Trucks & 4Runners 5 12-20-2005 08:23 AM
Did the Dollar bill test and Pop Pop Pop - Now What? MDToy 95.5-2004 Tacomas & 96-2002 4Runners 5 12-27-2004 03:15 PM
pop ups doink Off Topic Talk 8 10-22-2003 12:54 PM
Tricks to pulling plenum on 1990 4Runner 3.0 V6? boltman 95.5-2004 Tacomas & 96-2002 4Runners 3 07-16-2003 10:17 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
