Proper TB adj. on the 3.0?
Old 09-19-2003, 01:54 AM
Guest
Yoter's Avatar
Question Proper TB adj. on the 3.0?
What is the proper way to adjust the throttle body and how many RPM's should it idle at?
Old 09-19-2003, 04:38 AM
Victor's Avatar
Idle is 800 RPMs which is the needle just above the 750 mark on the tach for me (confirmed by the emissions test computer). Adjust the idle with the screw that faces towards you - tightening it in will lower RPMs and loosening it will raise them.
Old 09-19-2003, 06:18 AM
CTB
CTB's Avatar
Just for your info, I idle at 750 rpm when it is warm outside, and just slightly higher in the winter time (as if SC really has a winter!).
89fourrunner
02-17-2016 06:52 AM
tobylab
01-18-2016 07:06 PM
accuracy
08-30-2015 09:47 PM
klavender1
08-15-2015 01:51 PM
tobylab
07-12-2015 12:53 PM
Quick Reply: Proper TB adj. on the 3.0?
