problems after changing the brakes.....
Old 04-01-2006, 02:03 PM
fireteacher's Avatar
just changed my brakes (front) and put on some reybestos qs pads as well as having the rotors turned. Now i KNOW ( ) i should have replaced them and i didnt but heres the problem.
Still have the woble at highway speeds when braking but not quite as bad. also the left rotor was warped pretty bad, the guy let me watch him turn them.
shaould i say screw it and get new rotors..i only drove about 10 miles on the new pads so i dont think that will be a problem to re-use them..........
I KNOW I SHOULDA LISTENED BUT I AM A DUMB A$$!!!
Thanks in advance.....
Old 04-01-2006, 02:20 PM
surf4runner's Avatar
yes. & the pads will be OK.
Old 04-01-2006, 05:21 PM
i am going to get rotors but is there a possibilty it could be something else as well?
any ideas?
Old 04-01-2006, 06:38 PM
marko3xl3's Avatar
any ideas?
3rd gens always had that problem, because they use long-lasting hard compund pads. I could probably come up with a million things why the car would shake, but I know for a fact those wouldn't be it. It's the rotors bud.
If you really wanna hunt for things to check as far as vibration goes, feel free to search.
Old 04-01-2006, 06:49 PM
4runnermt's Avatar
Get the rotors and don't forget to break in the pads.http://www.zeckhausen.com/bedding_in_brakes.htm
Old 04-01-2006, 07:26 PM
Nam
Nam's Avatar
Somtimes alignment matters too!
Nam
Old 04-01-2006, 07:32 PM
agreed, i know for a fact that my alignment is slightly out to but i was going to fix this first,.....should i just leave the turned rotors on and have my alignment done?
Old 04-01-2006, 08:30 PM
manofsteele2003's Avatar
Get the rotors first and then if it's still there, an alignment. An alignment shouldn't cause a vibration while braking, but you should double check all your front end components for wear ie: tie rods, ball joints, ect.
Old 04-02-2006, 08:39 AM
ok also i somehow damaged a stud (hammer trying to loosen the rotor) and striped a lug nut in the process of trying to get it on. from other threads i have read, all i need to do is move the caliper, take the rotor off, and drive the stud out through the rear. now do i need to turn it or simply beat it out? also, do i need a punch cause i dont have one to get the stud out or after it gets close to flush, use a screw driver/socket extention/ect?
Old 04-02-2006, 03:00 PM
everything feels pretty good now, pedal is a little soft though but i will bleed it if it dosnt get firmer in a day or so. i borke the pads in as the link said and it was fun to stop that fast i tell ya!!!!!!!!!
thanks folx!
Old 04-02-2006, 04:19 PM
ebelen1's Avatar
thanks folx!
My pedal was a little soft after changing rotors and pads. After adjusting the rears, pedal got better. Have you done this yet?
Also, many have said that ss brakelines help w/ firming up a pedal. Haven't done this yet but will on the next set of front pads...
Old 04-02-2006, 04:38 PM
i did the ebrake method for the rears and i have 9 clicks for the ebrake to be firm. another method?
Old 04-02-2006, 05:23 PM
ebelen1's Avatar
I wasn't talking about the e-brake but the rear shoes. Have these been adjusted/cleaned? Adjusting/cleaning them can bring some more tension in the brake pedal, at least for me it did.
Old 04-02-2006, 05:47 PM
only way i know to adjust the rear brakes is by driving in reverse about 10mph and lifting the ebrake a few times to stop! explain your way...
Old 04-02-2006, 06:23 PM
Mr. Bob's Avatar
-Pull rear tires off
-Pull rear drums off
-spray with brake clean till clean
-adjust star wheel
-Install rear drums
-install rear tires
-torque wheels
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
Eggslinger
06-08-2019 03:32 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: problems after changing the brakes.....
