Problem with something when steering
Old Aug 1, 2005 | 12:52 PM
Chapman88SR5's Avatar
1987 4runner 22re 30in tires
when i turn my wheel all the way to the left and start driving i hear a really bad poping noise coming from the passenger side up front. any ideas?
Old Aug 1, 2005 | 01:02 PM
4Crawler's Avatar
Have a look at this page and see if that is the issue you are having:
http://www.4x4wire.com/toyota/mainte...ront_end/lube/
Old Aug 21, 2005 | 08:19 PM
could it be my struts or my shocks? now my alignment is worse too. too much mudding, its addicting (and only on a/ts)
Old Aug 21, 2005 | 08:20 PM
jimbo74's Avatar
i doubt its shocks..... it sounds to me like you are hitting hte steering stops...
Old Aug 21, 2005 | 08:23 PM
i thought of this too... but wouldnt that just make a noice when i first hit it and then not make a noise again? cuz this is a bad, bad popping noise, and i can feel it in the steering wheel a little
Old Aug 21, 2005 | 08:28 PM
Yamaha+Toyota=Fun's Avatar
My steering stop sometimes will make loud noises, but sometimes they dont. Just have a look at your tie rods, idler arm, pitman arm, etc.
Are you hubs locked?
Old Aug 21, 2005 | 08:30 PM
90runnner's Avatar
its the steering stops, i promise you. nothing to worry about. when you have the wheel cranked they rub together keeping the tire from rubbing the fender and are adjustable(not very much) incase you get larger tires. they are just two pieces of metal rubbing together and do no push the wheel back away so it will continue to rub making the noise until you turnt he wheel back towards center
Old Aug 21, 2005 | 08:36 PM
than how come this doesnt happen when i turn the wheel all the way to the right? is this becuase of my bad alignment?
Old Aug 21, 2005 | 08:39 PM
jimbo74's Avatar
sometimes the steering stops dont hit even at full turn... sometimes they do..... my truck makes a couple clunks on turns.... my ragjoint on the box clunks also as i have a steering extension and the steering stops also hit making noise
Old Aug 21, 2005 | 08:43 PM
hmm, is there anyway to make this sound go away? its bad
Old Aug 21, 2005 | 08:44 PM
It could be because the steering stops for the right side are in good condition and the ones for the left arnt.
Yotadawgjr
10
Aug 23, 2015 10:51 AM
terminator
Jul 27, 2015 07:13 PM
keithporter83
Jul 24, 2015 07:37 AM
voiddweller
Jul 15, 2015 03:56 PM
