Pioneer 4100 HU Installed with Cameras - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-03-2009, 11:29 AM   #1 (permalink)
Rock Slide's Avatar
Finally getting around to posting photos of my latest HU install I did about 3 months back…no real wiring photos, just photos of the final result. Big Thanks to IH8Mud forum member - 98 Snake Eater, for all his help guiding me through this install!
Opted for the Pioneer AVH-P4100DVD Unit. Paid $399 + shipping. Also purchased the Ipod cable and a couple cameras off ebay.
Before:
After:
Radio Source selected (BTW, that's a photo of my son I uploaded for my background):
Of course you can hide the icons too:
Mounted the ipod here (notice the notch I added in the tray so the cable would not interfere with the top closing):
View of the ipod screen:
Shot of the DVD in action:
And of course I add the "Relay Mod" to allow DVDs to play while the vehicle is moving. . Special thanks to GeoffSFAs10 (a forum member of NASIOC) for creating this mod (sorry, no pics of the wiring itself):
On a standard universal relay, you have 4 numbered tabs. On prong 87 and 86, attach a ground wire. Send these 2 wires to ANY ground. Prong 85 gets a tap from the remote wire coming off the Pioneer unit (you typically use this wire for your amp turn on). Take the parking brake wire and tap it into prong 30. After your relay is wired properly, stick it in the far back corner of your dash where you don’t have to see or touch it and enjoy DVD playback in any gear! It works because the remote signal trips the relay, the double grounds trip the relay back and thus pulses the parking brake wire tricking the vehicle into thinking the parking brake is on. Now when you select the source mode for DVD, a blue screen is first displayed and then you just hit the OK button to start watching the movie.
Baby Cam mounted. No need to hard mount this camera as sometimes we move his car seat from side to side. This is a "Normal View" camera with Night Vision I purchased off ebay for about $20.00:
Wiring was run as so:
Again, I sometimes have to move the camera from side to side, so I made sure I had plenty of slack in the wiring:
Rear View Cam mounted. It's a "Reverse View" camera with Night Vision I also purchased off ebay for about $20.00. It’s not hard mounted b/c I’m still trying a few different locations for it:
To switch between cameras, here’s what I refer to as my own version of BMW's idrive :
It’s a 2-Pole, 6-Position Rotary Switch. I cut the shaft down a bit and mounted a black knob on it. Here’s a stock photo of it:
Mounted:
The white line pointing straight up in the 12 o’clock position is OFF. Turn the dial to 1 o’clock and the rear view cam is activated. Turn the dial to 2 o’clock and the baby cam is activated. All the needed wiring has been run for 2 more cameras at positions 3 and 4, but they are not currently installed…still considering where I want to mount them. One will go under the vehicle, just not sure about the last one. This switch can handle a total of 6 cameras, but 4 are plenty for me.
One more shot for good measure:
Here's a diagram of how I wired the cameras to the switch. I ran the switch thru a relay, so in the event I leave a camera on when I turn the vehicle off, the camera itself will turn off too. Again, I have already run the wiring for 2 more cameras, just trying to find a place to mount them first:
Oh and the way this Pioneer unit is wired, the power antenna will NOT automatically go down when switching between sources. It will only go down if you physically turn the unit off. Of course to get the antenna to go up at all, you have to wire the power antenna wire from the stock harness, to the amp turn-on wire on the pioneer harness (this is even how it’s said to be done in the pioneer installation manual.)
I greatly miss this auto up/down feature for the antenna on our stock HUs. However, to combat this w/ the pioneer, I installed a switch to manually make the antenna go up or down at my choosing. I simply spliced into the power antenna wire and ran both wires thru a simple on/off switch. Works great. Found a use for that pointless pocket under the cigarette lighter and mounted the switch there:
__________________
2002 4Runner Sport 4WD
My 4Runner Profile
Accessories: SS 7.1 Lift Kit, WabFab 1" BL, TJM T15, Stubb Sliders, FX/TSX HID Projector Retrofit, 1st Gen Rollbar, Tundra Brake Upgrade, Hilux Surf Field Monitor, TRD Ivan Stewart Wheels, Nitto TG 265/75s, WeatherTechs, Hella HID 4000s, LED Tail Lights, JBL Speakers
Mods: Disabled DRLs, Disabled Keyless Entry Chirp, Disabled VTRAC/VSC/ABS, Fog Light Mod, Air Elbow Mod & Rear Diff Breather Mod
"Why fix a Jeep, when you can drive a Toyota?"
Rock Slide is offline
Old 10-03-2009, 11:35 AM   #2 (permalink)
MillerPKA's Avatar
you never cease to amaze me, if i wasn't starting the rear bumper build i'd be getting that head unit for sure, as always great writeup!
__________________
883/LC with OME/PC shocks ∙ 2" body lift ∙ ARB bull bar ∙ Safari Snorkel ∙ KC/IPF aux lighting ∙
315/75 BF Goodrich KM2s ∙ LC Wheels ∙ Vortex Cherrybomb ∙ Custom black/tan color scheme ∙ couple other things
Toytec 4Runner Catalog
MillerPKA is offline
Old 10-03-2009, 11:38 AM   #3 (permalink)
4runnerteen's Avatar
Man, just let me be the first to say that is extremely nice. Thanks for the pics too btw. But you seem to have done everything very nice.
I will be doing a HU upgrade similar to that soon cause I need a backup cam to for parallel parking lol.
__________________
99' 4Runner SR5 3.4L Auto 4x4
- Sony Xplod head unit
- 2 12" Pioneer 1200 watt max.
- 2 12" Rockford Fosgate Punch P1's.
- 1600 watt 4 channel powering everything.
- 500k MicroFarad Capacitor.
- 2 Pilot fog lamps in front bumper.
Yea... My truck still goes boom.... A little lol.
Needed less weight.
Stock from there on out.
4runnerteen is offline
Old 10-03-2009, 01:31 PM   #4 (permalink)
nice i have that exact same headunit and i love it
i got the rear view camera also mounted in the same place
had this unit for couple months now and never had problems with it ever since.
although one quesiton i wanted to ask
for your photo what size and resolution did you use? idk if its because of your camera but the picture quality looks really good. i mean mines isnt to bad but i feel likeyours seems to have better color ahha
thanks
awpsome is offline
Old 10-03-2009, 02:07 PM   #5 (permalink)
Rock Slide's Avatar
Thanks guys.
Weston, wait until you see what I've got planned for my TJM...paying WabFab a visit next weekend to have some simple, yet clean mods done to my bumper. We've only been trying to hook up for about 6 months now.
awpsome, the video looks ever better than the above photos look. I just took those photos w/ a simple point and shoot 6mp camera set at 3mp. Nothing special. I did tweak the video quality thru the HU settings too..it helped a little. Then again, I didn't expect HD quality from these $20 cameras, so for what they can do, I'm satisfied. The night vision works great for seeing the baby at night.
Maybe one day I'll upgrade to a more expensive cam for the rearview cam. When sunlight hits mine directly, the video produces an odd infrared looking image.
__________________
My 4Runner Profile
Old 10-05-2009, 08:05 PM   #6 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
I can't wait the tear up...I mean play with those new cameras.
Looking good as always Bill.
Pictures don't do Bill's truck justice...cleanest I have ever seen.
waskillywabbit is offline
Old 10-05-2009, 08:08 PM   #7 (permalink)
camo31"10.50"'s Avatar
do you have a roll bar in the back?..what are those big black bars in the pics??????
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE
1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous
"Its still a toyota man.. Dont deprive it of its capabilities.."
"If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009
camo31"10.50" is offline
Old 10-05-2009, 11:45 PM   #8 (permalink)
what brand are the floor mats?
Sea.Jay is offline
Old 10-06-2009, 05:30 AM   #9 (permalink)
Rock Slide's Avatar
Thanks. Still got room to mount 2 more cameras somewhere.
Quote:
Have you been living under a rock or what? Kidding, yes, it's a roll bar. One from a 1st gen 4Runner. Click the link in my sig for more photos and a link to the write up of the install.
Quote:
You too Sea.Jay...click the link in my sig for more info. I did a comparison thread between weathertech, husky & oem rubber mats. You'll see why I chose weathertech.
__________________
My 4Runner Profile
Old 10-06-2009, 08:30 AM   #10 (permalink)
xskydivingdudex's Avatar
Send a message via AIM to xskydivingdudex
nice install rock slide, ya i need to get this done bc i have a 2 month old and its so hard to see wat shes doing and i wanted a backup cam so i will def be using this for a reference.
__________________
2002 4runner Sport Edition
Mods: Brush Guard, PIAA 520's, BAJA Lights, Backup Lights, Sylvania Silverstars, Tacoma Whip, 20% Tint (All), Cobra 19 DX IV CB Radio, PA Speaker, 8'' CB Antenna, Escort Passport 8500 x50 Blue, Mio 320 GPS, Alpine Head Unit with IPOD, Nitro 1200w Amp, 3 10'' MTX Road Thunder Subs, Custom Sub Enclosure, 12 LED Map and Dome Lights, Viper 5901 Remote Start Alarm
Lift: OME Coil and Comfort Shock Lift (882/891), 285/75/16 BFG All-Terrain KO's
My Profile
xskydivingdudex is offline
Old 10-06-2009, 09:09 AM   #11 (permalink)
Rock Slide's Avatar
Thanks. Only thing I wish I would have done instead, was install it sooner! I did not get around to purchasing & installing everything until my little boy was 4 months old. He's a little over 7 months old now.
The night vision part of the baby cam works great too for seeing him in pitch black darkness. Def well worth it.
__________________
My 4Runner Profile
Old 10-10-2009, 11:40 AM   #12 (permalink)
Rock Slide's Avatar
The stock CD/cassette/AM/FM stereo has a diversity antenna setup that uses both the normal-sized front fender antenna jack and the smaller-sized rear window antenna jack. However, aftermarket stereos only accept the normal-sized front fender antenna jack. I installed my new Pioneer 4100 as such and noticed a decrease in reception quality. To defeat this and turn both front antenna and rear diversity antenna into one big antenna, here’s what I used:
1. METRA 40-UV43 Motorola Antenna Y-adapter = $9.06 from Amazon ($3.58 + $5.48 shipping)
2. Scosche Mda-B Micro/Delco = $4.95 from Amazon (free shipping)
The Y-adapter has 2 normal-sized female jacks going to 1 normal-sized male jack:
The Scosche Mda-B adapter converts the smaller rear antenna jack into a normal sized antenna jack:
Stock 2 antenna jacks:
Plug the rear antenna jack into the Scosche adapter:
Plug the Scosche adapter into one of the Y-cable’s female jacks. Plug the front fender antenna jack into the other Y-cable female jack:
No photo, but to finish, just plug the Y-adapter's male jack into the back of your stereo.
The Metra 40-GM10 GM Antenna Adapter is another adapter that works just as good as the Scoshe adapter, but it’s more expensive and roughly 10” long. It was on Amazon for $11.77. I bought it to try it out, but since the Scosche adapter works just as well, I’ve since returned this one:
Now I can flip my antenna switch to lower the power antenna and still get good stereo reception since the rear glass antenna is now active
__________________
My 4Runner Profile
Old 10-10-2009, 06:35 PM   #13 (permalink)
stunning-really helpful. very specific that is what I like. appreciate that.
thanks for those radio antenna adapter part numbers- I want to be ready when I have my stuff all pulled out.
okay so you use the idrive imitation to select the camera -it is always "hot" then right? not tied into reverse in any way correct?
__________________
99 4Runner SR5 4wd 3.4/5 spd-
Fact. Rr. Locker/Diff Breather Ext.
Old Man Emu lift springs- 881 fronts/890 rears
O/M/E shocks- N91s fr./N86 rr.
All Pro Off Road welded sliders-prevent body damage!
ARB"Taco"bumper/Gamiviti clear lenses/Hella 500s
Redline Tuning hood struts/Bushwacker Extend a Fenders
all my photos are over on Facebook now-I gave up on photo hosting sorry....
http://www.facebook.com/album.php?ai...5&l=5795132731
Ron Helmuth is offline
Old 10-10-2009, 06:49 PM   #14 (permalink)
Rock Slide's Avatar
Thanks!
Correct, the cameras are not tied into reverse in any way. When the idrive switch is pointed straight up to 12 o'clock, it is in the OFF position. Turn the switch one click to the right and the back up cam activates. Another click to the right and the baby cam is activated. So technically, the switch is always hot when the ignition is on. The cameras are not on until I turn the switch to the appropriate channel.
__________________
My 4Runner Profile
Old 10-10-2009, 07:17 PM   #15 (permalink)
wow rock slide that was some good info on the rear antenna terminal. i had no idea about wat that was, i assumed it was just the AM channels but now that u have givn insight on this ill have to do this for sure but was wondering if u got the pioneer on ebay? i was looking for an alpine bc i love that brand but they are so expensive compared to the pioneer...
__________________
My Profile
Old 10-10-2009, 07:31 PM   #16 (permalink)
Rock Slide's Avatar
Having the rear antenna hooked up really does increase reception for both FM & AM. I can actually leave my power antenna down and still get good reception w/ the rear now functioning.
I purchased this pioneer here for only $399: http://www.artofsale.net/Magento/ind...hp4100dvd.html. Although, now I see that it's since gone up $10 to $409. Still a great deal. Crutchfield for example, wants over $500 for it.
__________________
My 4Runner Profile
Old 10-10-2009, 07:35 PM   #17 (permalink)
ya i have the taco whip but im sure itll help with reception bc when its cloudy or like something in the way i start to get static... Ill be doing this prob really soon.
Thnx for the link, ya ill prob have to wait a little while to get that since its such a large chunk of change. My lift has put a big hole in my pocket and there are so many things i still wanna do.
__________________
My Profile
Old 10-10-2009, 08:07 PM   #18 (permalink)
98 SNAKE EATER's Avatar
Thumbs up
Looks great
Love the baby cam
98 SNAKE EATER is offline
Tags
4100, avh, avh4100, background, camera, cameras, changing, hu, image, installed, pioneer, rear, resolution, toyota, tundra, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
