pinging on 3.4l taco
Old 10-27-2004, 01:16 PM
GoudyMan's Avatar
i have a 2001 3.4l 4x4 xcab 5spd.
anyways, i am getting quite a bit of pinging. I notice if I use 89 then there is not as much pining... but its still there....... any ideas??
do the 3.4l usually ping a little?
thanks
Old 10-27-2004, 01:19 PM
InFlames's Avatar
thanks
Is it supercharged? any other mods?...try using a higher grade of gas.
Old 10-27-2004, 01:33 PM
midiwall's Avatar
Yeah... pinging is never "normal"...
Any chance that you changed your plugs to the "wrong" ones? Maybe something hotter?
Like InFlames asked, are you supercharged? Is there anything else that you've done to your engine - or not done! (dirty air/fuel filter, deckplate mod, ISR mod, ECT mod, etc...)
Old 10-27-2004, 02:09 PM
drabnor's Avatar
thanks
have you changed your spark plugs latley? did you gap them correctly? they should have a gap of .43
Old 10-28-2004, 04:53 PM
Mikey's Avatar
My 98 pings. More lately than normal. I wonder if the gas is getting cheaper? I didn't have many problems with 87 octance before
Last tank I bit the bullet and filled up with 89 octane. Much, much less pinging. It runs much better and smoother too. I guess I just start feeding it 89 at 2.09 a gallon :cry:
Old 10-28-2004, 05:15 PM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
if your fix is using 89 octane, then try alternating between 89 and 87 each fill-up from about 1/2 tank. see if the minor increase from 87 to about 88 reduces it. it could save you a few bucks.
Old 10-29-2004, 04:36 AM
Away
Dr. Zhivago's Avatar
I would check your MAF sensor. It's probably dirty.
My .02
G
Old 10-29-2004, 05:00 AM
rimpainter.com's Avatar
Running 89 is not a fix. Use it until you can properly diagnose the problem and fix it. Don't just settle for it.
Old 10-29-2004, 05:18 AM
Away
Could also be clogged injectors and/or a dirty combustion chamber. Run some Redline SI-1 thru your tank. Best fuel system treatment ever. You'll find it at good, performance oriented auto parts stores.
Peace.
G
Old 10-29-2004, 06:42 AM
Mikey's Avatar
With mine I know I have cleaned the MAF, did the seafoam thing and all but I still get the pinging. I do have a problem with a rough idle and I wonder if it's connected?
Old 10-29-2004, 06:54 AM
Mikey-
Did you check your plugs?
Old 10-29-2004, 07:01 AM
Mikey's Avatar
That's next on my list, I only have about 20K on them though.
Old 10-29-2004, 09:16 AM
midiwall's Avatar
I see you did the deckplate mod... does the pinging get better/worse with the deckplate in/out? If it changes, then that can help diagnose the problem.
Old 10-29-2004, 05:25 PM
Mikey's Avatar
I can't say I know. I did that over a year ago and never put the plug back in. I liked the power too much. That's an interesting idea though. Maybe I should try and put it in and find out.
nvwiggins
13
06-16-2016 03:05 PM
stanz
10-30-2015 10:33 AM
LCE_Performance
10-01-2015 01:03 PM
Toys4parts
09-26-2015 01:56 PM
Tacoma1313
08-17-2015 05:44 PM
Quick Reply: pinging on 3.4l taco
