Pin out of cig lighter?
Old 01-09-2017, 04:53 PM
thealexdexter's Avatar
Really? The 4runners have non standard cig lighter wiring when the center pin is negative and the shell is positive?
I've tested two different ones, same result. No usb plug in sockets will work without requiring something..
Amicrazy?
Old 01-09-2017, 06:29 PM
TheDurk's Avatar
Amicrazy?
Yep. Somebody messed with yours.
Old 01-09-2017, 07:05 PM
My truck wiring has two spade terminals. The large one goes to ground. Small to v+. Is this not what others have?
I take it someone switched my truck wiring, I guess. It seems so much like it was from the factory.
Does the lighter itself care which side is positive, I wouldn't think so. It's just a resistor, yet mine did not work. Perhaps my wiring is so poor/ resistive if it was messed with that it can't draw enough current to heat the lighter?
Old 01-10-2017, 02:01 PM
wyoming9's Avatar
Red face
You are sure the lighter is good.
They can die of old age
Maybe someone had the dash out and got the wires on wrong
Old 01-10-2017, 02:45 PM
Can't say for sure on the lighter. I am measuring the socket and connector in the truck. Voltage there, just opposite what I expected.
