YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 11-24-2002, 04:46 PM   #1 (permalink)
PCV Valve
Where the heck is it:confused:
on my 2nd gen 3 litre??
KraTOR is offline
Sponsored Links
To remove this ad, register today!
Old 11-24-2002, 05:44 PM   #2 (permalink)
Paul H.'s Avatar
Good luck in finding it. It is on the right side of engine manifold just inboard of your vacuum lines. Very difficult to find and even tougher to replace. I gave up on mine and took it to a shop. Cost me $50.:cry:
__________________
92 4Runner SR5 V6 4X4
Skyjacker Nitro shocks, Pro-Comp steering stabilizer, clear bumper lenses, lund windjammer, OME standard coils, ISR mod, inlet pipe removed, Bushwaker Fender Flares.
2002 Tacoma Prerunner V6 Xtracab. Lund Intercepter bug guard, rear glass sunshield, Bilstein shocks on rear.
2004 Honda CRV EX stock belongs to wife.
Quote:
Originally Posted by habanero View Post
I did a lot of masticating today.....and now I'm going to go do some more.
Paul H. is offline
Old 11-24-2002, 11:50 PM   #3 (permalink)
butnut's Avatar
Another reason the 2.7 is cake to work on. It's right on top of the valve cover. Took me all of 30 seconds. Spark plugs...ehhh maybe 5 minutes...if I'm really draggin butt. Ya got me beat power wise...oh well.
butnut
__________________
Brian
B like dat den...
2006 DuB CaB Tacoma
Speedway Blue TRD Sport
butnut is offline
Old 11-25-2002, 04:03 AM   #4 (permalink)
Jay
Send a message via ICQ to Jay
It is located under the intake plenum on Bank 1. Bank 1 implies the side of the engine with Cylinder #1. In this case its the passenger side.
Replacing of the PCV valve on your 3.0L will be tricky. I suggest that if you are seriously gonna replace it, to just plan on taking off the intake plenum. The reason being, the gromett that the pcv valve sits in is going to be hard/brittle if it is the orignal. Making it difficult to get out/in and possibly causing a vacuum leak.
List of part I suggest. ( All toyota parts )
1. PCV valve
2. Hose
3. Gromett
4. Plenum gasket
5. (2) small EFI gaskets ( For cold start injector supply tube )
Good luck.
Jay
__________________
Jay
98 X-Cab Tacoma
3.4L Manual Trans. | TRD Fender Flares | Weld Wheels w/ 31 x 10.5's
Jason Larsen
Master Diagnostic Technician - Beaverton Toyota (Portland, Oregon)
Wendsday - Saturday by appointment only.
(503)626-7200 (ask for me by name)
Jay is offline
Old 11-25-2002, 09:28 AM   #5 (permalink)
Ok..forget it. I'll get it done the next time the timing belt / valve timing are done.
Thanx for all the input
KraTOR is offline
Old 11-25-2002, 02:00 PM   #6 (permalink)
Mohamed's Avatar
ah don't feel bad, I felt the same way.
__________________
2002 Imperial Jade Mica Tundra
2005 Acura TSX 6MT Navi
2006 Suzuki GSX-R600
Pic's of my Tundra
Mohamed is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
PCV valve 2.7. Help! crazy_horse3030 95.5-2004 Tacomas & 96-2002 4Runners 4 03-01-2007 12:23 PM
pcv valve Eneas28 95.5-2004 Tacomas & 96-2002 4Runners 5 03-05-2005 12:59 PM
Why only one PCV valve? ChickenLover 95.5-2004 Tacomas & 96-2002 4Runners 15 01-01-2005 07:10 AM
PCV Valve kevin444 Maintenance & Repair Archives 3 10-02-2004 05:53 PM
pcv valve ? bugalu Maintenance & Repair Archives 2 09-16-2003 06:37 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
