Passenger Airbag Indicator Light Problem
Old Sep 18, 2006 | 05:07 PM
FingerMan20's Avatar
The light in the passenger airbag on/off selector didn't work when I bought my truck, and it didn't work for 4 months. I didn't even know it was supposed to light up, but then I started to notice the green light when I would hit bumps. It's in a '98 Burrito 4 cyl.
I took the switch out, and carefully examined it, and I could see no frayed connections, no loose or disconnected... uh... connectors either. As I re-assembled it, i noticed that if, upon reinsertion of the switch assembly, I tweaked it to the side, and replaced it ever-so-gently, the light would stay on, but only till i either hit a good bump or re-started the truck.
Is this a big problem? Does anyone have experience with such a problem, and if so, is it just a light, or does the fact that it isn't illuminated mean my passenger airbag won't deploy?
Old Sep 18, 2006 | 05:24 PM
User 051420's Avatar
I wouldn't take any chances with an airbag indicator not working properly. It _could_ be a bad bulb, but who wants to test it? Have it checked out.
Old Sep 19, 2006 | 12:02 PM
profuse007's Avatar
i dotn think its a bad bulb. its either theres a false triggering or module is failing.
ashersullivan88yota
Jan 18, 2022 05:37 PM
lledwod
Aug 30, 2016 01:03 PM
Johntom240
7
Jul 13, 2015 12:18 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
