Parking Lamp Wire?
Parking Lamp Wire?
I have tried to read over the wire diagram but I can not seem to make head or tails as to which wire is for the parking lamps.
I would like it so when I turn my parking lamps on I can turn my fog lamps on as well.
I have searched here as well, but came to dead ends, or thread that talked about rewiring the parking lamps to work as turn signals so.
Please someone help this nob here.
Thanks,
Avy
P.S. At least I know the regular head light wire is Red&Yellow for anyone that needs to know.
Thanks,
Avy
YotaFun, I just did a reverse gauge install and I have a 1998. I needed to pick off the parking lights for the gauge illumination, so they would come on when I turned on the parking lights. I am doing a write up on this but you need to go to your mail fuse block.
There is a large white plug. On this plug you should find a green wire which will be the 4th wire from the left on the top row
I spliced the positive gauge wire for my gauge overlays and it worked perfect If this is what you are trying to do then this is the wire you are looking for. I would not expect this line to be the carrier of any power but would be a great tap in for a relay control line. Also this will be the same wire to look for coming from either side wire harness for the side marker lights. Thats how I found the color for the lights and then traced it back and then used a multimeter to determine if it was the right wire on the main fuse block under the dash. There is not alot of room in there. but good luck. Hope it helped,
the1998sr5
15
07-14-2020 08:35 PM
CanRunner
07-20-2015 01:29 PM
