| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
oil filter relocation kit for 3.0?
__________________
88 3.0 XCab, K&N fipk, Borla cat-back,Magna Flow Cat, Downey frame brace, Downey 2" rear springs, BJ spacers, Aisin manual hubs,B&G Fiberglass bed, extended diff. breathers, Bilstein HD shocks, Rancho RS5000 stabilizer, Brembos & TRD Pads, Revos, Hella 500s, 4 runner bucket seats and console ETC ETC... |
#2 (permalink) |
Seems like Northwest Offroad had a kit at one time.
The Toyota filter has a check valve in it to keep the filter full of oil, so that upon startup, the engine runs less time before the oil system comes to full pressure. If you get a remote kit, make sure thatit has some sort of check valve in it to do the same or you may just be cutting your engine life short by longer dry startups.
__________________
'99 4Runner SR5 4WD, 5-SPEED. Abzug's vehicle for urban expeditions, navigating flash floods and debris flows (try 12-15 inches of rain in one week). It always gets her home. '95 4Runner LIMITED 4WD, 5-SPEED, over a quarter million on the original 3vze & headgaskets. TRD heavy duty clutch, TRD heavy duty flywheel, OME 900 springs and shocks. This old gal has gotten me out into the field, and back for 8 years, never failed to start or gotten stuck. |
#3 (permalink) |
didn't know you could relocate an oil filter
__________________
1992 "Truck" 1978 Land Cruiser FJ40 pig and elephant DNA just won't splice :( ***DO NOT CLICK HERE*** |
#4 (permalink) |
Try this : http://www.tdperformance.com/TransDapt.html
There is a dealer locator here as well. If the filter is mounted vertically you won't have to worry about dry start-ups.
__________________
'98 4Runner SR5, V-6, 5-speed, 35" Baja Claws, 17x9 Eagle Alloys, E-Locker, 3" Susp Lift, 3" Body Lift, Elbow mod, Deckplate Mod, "D" gasket mod, Silverstars, Headlight Film, 67" TG Sliders, 8500lbs Portable Winch, Magellan GPS... Next on the list: 4:88 gears |
#5 (permalink) |
You can buy them at just about any automotive store. My local Autozone sells them. JC Whitney and Performance Products are another source.
__________________
Chris Mine-94 SR5 4-Runner, 3.0, 4X4, Aisin Hubs, Yakima Load Warrior, 210k Miles | Wifes-99 Limited |
#6 (permalink) | |
Quote:
__________________
Dave Currently own no Toyotas :( |
#7 (permalink) | |
Quote:
You're going to use hydraulic hoses to attach the remote filter to the engine and those hoses have a volume that has to be filled up with oil under pressure before it can be sent to the engine. I'll just keep the stock setup on my engine, use Mobile 1, and change about every 5K. It's worked so far on every vehicle I've owned. I've NEVER worn out a Toy engine...Now VW's are a different story.
__________________
#8 (permalink) |
I was just looking at one from Performance Products the other day. I was going to ask if anyone had ever done that before. I assume it should be relatively easy to mount a cooler in front of the radiator on my 2nd Gen. Am I way off base on that? Me thinks a good tech write up could be on the way from someone.
__________________
90 SR5 fully rebuilt V6 3.0 5spd/Downey K&N intake kit/ISR/Downey headers/Magnaflow highflow Cat/Spintech Muffler/NWOR 1&1/2" lift rear springs,Torsion Bars,Steering Stabilizer/Edelbrock IAS Shocks/Poly front&rear bushings/Bushwacker fender flares/Genuine steel Nerf bars (Brush & taillight guards removed)/weatherguard ventshades/TRD Offroad body emblems/Body stripes Removed/Aluminum Rims/33x12.50 BFG AT's/Aisin Manual Hubs/4:88's in both diffs/Flexalite elect. Fan Conversion. |
#9 (permalink) | |
Quote:
When you buy a filter relocation kit it will come with rubber line and barb fittings. Toss that stuff in the junk and purchase some braided line and the correct fittings and adapters for it. Unless you want to replace them every 2 years or so and put up with leaks. Your call on that I guess... You can click on "my 4Runner" in my sig to go to webshots and look at the filter kit install on my truck. Good luck!
__________________
2000 4Runner SR-5, 4X4, 5 Speed, Toyota locker. Dunlop R/T's, cheap mudflaps, remote oil filter, deckplate. My 4Runner |
#10 (permalink) | |
Quote:
__________________
#11 (permalink) | |
Quote:
I used -8 hose on my 4Runner but they're really short thanks to the place I found to mount the filter bracket. It might be a good idea to use -10 hose if you're running any distance or plumbing in a cooler etc...
__________________
2000 4Runner SR-5, 4X4, 5 Speed, Toyota locker. Dunlop R/T's, cheap mudflaps, remote oil filter, deckplate. My 4Runner Last edited by JSharp; 07-31-2004 at 07:21 AM. |
#12 (permalink) | |
Quote:
__________________
06 Subaru WRX |
| Tags |
| 1030, cylinder, dapt, dual, filter, forum, inline, kit, kits, northwestoffroad, oil, pathfinder, pro, relocation, relocator, remote, trans |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| oil filter relocation kit for the 22re | van7559 | 86-95 Trucks & 4Runners | 5 | 12-16-2006 07:18 AM |
| What oil filter relocation kit? | 2000t4r | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 09-05-2005 08:44 PM |
| oil filter relocation kit | Lone4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 03-10-2005 01:23 PM |
| Oil Filter Relocation Kit........ | 2000t4r | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 12-28-2004 07:47 AM |
| Oil Filter Relocation Kit | obxfishn | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 03-19-2004 09:06 PM |
