Oil change question - 3.4L V6
Old 12-15-2003, 11:20 AM
obscurotron's Avatar
Cool Oil change question - 3.4L V6
OK I tried asking this on *another* board, but the folks who answer have this habit of not reading the question and answering questions that weren't asked. I'm hoping the IQ level is higher over here.
That said - how long should it take for the engine oil light on the dash to go off after an oil change (oil drain and refill + new filter) on the first start? This is on a 3.4L V6. On my 2.7L it only takes a second. On the 3.4 it took 3-5 seconds or so. After that first start, it goes off w/in 1 second. Oil level is good, no leaks, no tailpipe smoke.
The useless replies I got were:
1. Fill the filter - Uhm hard to do when it's hanging upside down on the V6 block.
2. The oil light isn't a "time to change the oil light" Well NO SH#T! I didn't ASK that. uGh.
Thanks folks.
Old 12-15-2003, 11:26 AM
CLin9383's Avatar
i think mine usually takes 2 or 3 seconds...but i dont think 5 seconds would mean it's bad or anything..as long as it goes off i would think it's a good thing..right???
Old 12-15-2003, 11:31 AM
4Runnerman's Avatar
The 3-5 seconds sounds normal for the initial startup after you change the oil and filter. ON subsequent startups the light should go out after a second.
The reason the light stays on longer after an oil change is because the oil filter needs to refill with oil before the engine can attain the proper oil pressure. While this is happening the engine oil pressure is lower than the oil pressure sensor wants, so it holds the light on. To my knowledge, there is no way to 'pre-fill' the oil filter on a 3.4L since it angles down toward the block.
Good luck.
Old 12-15-2003, 11:38 AM
Awesome. Two sane answers in <30 minutes. Thank you both. That makes sense!
w0000t
Old 12-15-2003, 11:52 AM
CLin9383's Avatar
sanity is in the eye of the beholder...MUHAHAHAHHAAHAH
Old 12-15-2003, 12:46 PM
1Runner's Avatar
Re: Oil change question - 3.4L V6
Thanks folks.
To answer your question, lets break it down.
"X" is the unknown here. Lets go back to basics. To find the unknown we must first find out if everyone agrees that Beyonce Knowles is a hottie. Assuming that any sighted person would agree that yes, she is a hottie, we must find the unknown speed of any south bound 'coon hound. Taking into consideration female 'coon hounds are consistantly faster than male 'coon hounds we find ourselves wondering just why in the hell you started a thread about Beyonce Knowels racing a 'coon hound.
WHY ARE YOU WASTING MY TIME? Cant you do something constructive w/ your time?
Old 12-15-2003, 01:46 PM
MTL_4runner's Avatar
2-3 seconds would be typical but as long as it goes off then nothing to worry about!
Old 12-15-2003, 01:49 PM
44Runner's Avatar
odd, I have never seen my light go on...
Old 12-15-2003, 02:29 PM
Tacoma Dude's Avatar
From the sounds of it - looks like everyone's talking about how all the warning lights kind of go on when you have the key in the on position with the engine off.
EDIT:
Kind of like the airbag light...
Old 12-15-2003, 08:41 PM
Billrunner's Avatar
thats cuz the 99s dont need oil
Old 12-15-2003, 08:47 PM
44Runner's Avatar
Damn, I knew I was doing something wrong. And to think of all the money I wasted on synthetics...
smthwsn357
12-04-2023 02:08 AM
bigjstang
08-25-2021 12:41 AM
Huntingtruckcletus
07-08-2015 05:26 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Oil change question - 3.4L V6
