Oil in air filter
Old 12-20-2003, 01:42 PM
2runner's Avatar
Oil in air filter
hi, I checked my air filter today and noticed there is oil in the bottom of intake box and part of the filter. I searched the forums but couldn't find anything on it. Is this bad? Thanks.
Old 12-20-2003, 02:16 PM
partszar's Avatar
oil in air filter
My first thought would be the pcv valve or hose leading to it is clogged or pluged. That would cause excess pressure in the crankcase and force oil out of the engine. I've seen it happen on several different import and domestic vehicles (not going to bad mouth the manufactors). HTH
Old 12-20-2003, 02:48 PM
Nobody's Avatar
Welcome to the board 2Runner....is it a stock filter? and what year Runner?
Old 12-20-2003, 02:54 PM
2runner's Avatar
Thanks, its good to be here........The air filter is stock and my runner is a 98.
Old 12-20-2003, 03:38 PM
rugerm44's Avatar
blowby
Check the compression to.If its got a lot of miles? It could have a cracked piston ring.I had a 22r do that one on me, But it had been there and back.Just something to think about.Dose it use oil and is it smoking any out the tail pipe.Dont panic these are just a few things to check.The sooner you find the problem the less damage it will do.
Old 12-20-2003, 03:44 PM
2runner's Avatar
Recently I have noticed white smoke coming out of the exhaust, but it only happens about once a week, also i have noticed on long road trips my 4runner will use almost all of its oil.
Thanks for your post.
Old 12-20-2003, 03:55 PM
kyle_22r's Avatar
i always have a good sized puddle at the bottom of my filter. probably because i have shot rings from 300k on the motor
smthwsn357
12-04-2023 02:08 AM
the1998sr5
15
07-14-2020 08:35 PM
Eggslinger
06-08-2019 03:32 PM
Alex Bessinger
08-31-2015 09:17 AM
ryerye13
07-14-2015 08:27 AM
Quick Reply: Oil in air filter
