Off-road tire recommendations?
I'm considering the GOODYEAR MT/R and BF GOODRICH MT
It seems like alot of people here like and use the MT/R which is why that's my first choice. I can get them for $170 ea (including mounting/balance/valves). That beats tirerack which has them for $166 (not including shipping or anything).
Opinions on the tires and how well they work? Obviously they will be on the road so do they do ok on the road?
I know this is well-worn ground but the search function is on the fritz and I'm buying tomorrow.
Both are great tires. MT/R's definitely have a tougher sidewall if you're going to be using them on the rocks, which is why they are the preferred tire for the masses over any other for a daily driven rig.
Expect 45,000-50,000 miles on them. The KM's might last a touch longer.
Road manners are good and relatively quiet for the MT/R. Work great in rocks, rain and snow. Less so on ice and mud, though they have done really well for me in the mud.
Go with your first instinct and order today!
Originally posted by Billf6531
The big advantage of the BFGs is the 3 ply sidewalls. Ask your off-roading friends how many tires they've ruined due to cut sidewalls.
I bet if you ask your friends (assuming an equal number of owners for each tire), more will have chopped their KM's. Still a great tire, though, I'm not disputing that.
Those are the two best choices IMHO. MT/Rs do have stronger sidewalls. BFG KMs may last slightly longer and cost slightly less.
I'll go with MT/Rs again when the time comes.
I still will go with cheap ATs when I get around to taking my old wheels in. Cheap 30s for daily trips, 32s MTRs for trails and vacations.
Thanks for the info guys.
I looked at theProComps and Briges but I think the MT/R is for me.
Thats odd the MT/R doesn't do as well in mud. Doesn't MT stand for Mud-Terrain?
I am guessing that it is more slippery in the rain because of the big lugs and big spaces give a smaller contact patch on the road. Should I sipe them? I'm afraid I'll chunk a lug on rocks if I sipe.
There is a warranty that will cover all damage to the tire (including off-roading, nail, sidewall,etc) except it won't cover lug chunking off unless it is down to the cords. They say it's only cosmetic otherwise. Whatever, it's still a good deal I think.
They had the MT/R's on display and MAN! those lugs look meaty! This is going to be a huge difference so I'm looking forward to it. The stock Dunlops are barely cutting it ON road so you can imagine how I feel about them off road!
MT/Rs
Originally posted by Toyo_Runner96
I heard something that the MT/R's tend to not stay round? I think it was Gadget's experience with them (not 100% sure though)
I have the Goodyear 285/75/16 MT/Rs and I love them. Compared to any other off-road tire, they rule, and if you take care of them and rotate and balance them like you should, you'll get 40K from them easy. As for road noise, folks who want an off-road vehicle with off-road tires that rides as quiet and handles like an Avalon are fooling themselves. Road noise is minimal so just turn up the radio!
EDIT: All four of my tires were less than 14 on the road force test using the GPS9700 last time I had them done. Anything over 16 is unacceptable and from what I understand if it is like 30 and a new tire it should be considered defective and replaced.
Brian
MT/R = Maximum Traction Reinforced
I have had problems with my MT/R's with balance and the like.
When aired down, they do sick things on rocks. I don't have enough power to really spin them in mud.
BFG sidewalls are notoriously weak. When I tore my MT/R in Colorado, it looked and felt substantial.
When it is time for new rubber, I think I will look elsewhere. Krawlers make a lot of sense and the price should be down by then.
I have had upward of a pound per side of the wheel and get balanced around once a month. My best Road Force from the magic machine was 40 something, IIRC. After trimming Gadget had some in single digits which is astonishing.
Ive had BFG MTs and Goodyear MTRs...I like my BFG's much more! Same experience with the MTRs, they wont balance and wear unevenly (regardless of rotating tires). If I was getting new tires though, Id look for something besides these two...there are better tires out there that arent made by the big tire companies.
the1998sr5
15
07-14-2020 08:35 PM
thzpcs
10-03-2015 07:39 AM
FS[PacSouthWest]: 1988 4runner $1500
4x4-runner
08-03-2015 07:14 PM
TJWilly
07-31-2015 02:05 PM
