Off Road Enhancements-Tech write-up...
Old 08-21-2003, 06:00 AM
hillbilly's Avatar
Question Off Road Enhancements-Tech write-up...
Anyone know if the "Disabling The Toyota 4Runner Factory Electric Locker Safety" write-up posted by HBoss can be done on a '01 which has all the VSC/ABS bull˟˟˟˟˟ linked to the 4x4 system (+ locking center diff)??
Old 08-21-2003, 07:16 AM
HBoss's Avatar
Hrmm...I'll bet the wiring is a little different. It only lets you lock your center diff while in 4Lo?
Old 08-21-2003, 09:01 AM
hillbilly's Avatar
Well... no. Now that I think about it, I can push the 'center diff lock switch' on the dash and lock the center diff anytime I'm in 4WD. Here's the kicker though. It will ONLY disable VSC when I've locked the center diff and put it in 4Lo. Anything other than 4Lo and the VSC (ABS) system still activates to prevent wheel spin.
Old 08-21-2003, 09:48 AM
rwmorrisonjr's Avatar
Location: Home: Aurora, CO; Work: The People's Republic of Denver
Hillbilly,
When you lock the center diff, the VSC is diabled, hence the "VSC OFF" light on the dash. What stays enbaled is the ActiveTRAC system that replaced the e-locker for 2001-02 and beyond. It also uses the ABS system to imitate a center locker and to transfer power between the wheels. This works in both 4Hi and 4Lo and there isn't a way to disable it unless you remove the ABD computer.
Old 08-21-2003, 09:59 AM
hillbilly's Avatar
You're right RW! Thanks for pointing that out. I knew that, but sometimes my fingers chatter faster than my brain. I'll assume you meant the ABS ECU, not ABD?!?
Old 08-21-2003, 10:01 AM
Oops, fat-fingered that one. ABS it is!
Old 08-21-2003, 10:06 AM
hillbilly's Avatar
I feel your pain brother...
Cycles
09-29-2015 06:37 AM
Toys4parts
09-26-2015 01:56 PM
Project90
09-24-2015 11:40 PM
JamesDINAN
09-22-2015 05:37 AM
altydog
09-20-2015 07:37 PM
Quick Reply: Off Road Enhancements-Tech write-up...
