Oem Wire Harness for Hella Fog Lights
Old 02-07-2005, 11:51 AM
rev hank's Avatar
Question Oem Wire Harness for Hella Fog Lights
Have the oem Foglight wire harness(Hella Discontinued Part NO.96506, Toyota
Part #00550-89970WH) Closed system:harness, two plug ins for lights, relay, fuse holder, switch. It's basically a plug and play set up, but not certain which lights will fit the plugs. I'm thinking Hella 450.
any suggestions?
Thanks, Rev Hank
Old 02-07-2005, 12:30 PM
SLC Punk's Avatar
Performance products sells both the individual lamps or you can get the complete kit from them.
Old 06-29-2005, 06:52 PM
dv82u's Avatar
Fog Lights
Hey I saw that you had installed the performance fog lights. I installed mine, but it's not working. I checked the wiring, but I not so sure about the red/yellow wire at the bottom of the steering column. When I tried it, the fog light switch was on when I turned it on, but the fog lights don't work. Any advice? It's starting to frustrate me.
MO transplant
04-23-2023 11:58 AM
Regency
20
01-03-2020 07:43 PM
msane99
07-17-2015 10:13 AM
88yodabasket
07-13-2015 01:32 PM
Johntom240
7
07-13-2015 12:18 AM
Quick Reply: Oem Wire Harness for Hella Fog Lights
