OEM valves and seals
Originally Posted by TRunner
When replacing these, should they all be OEM? I am pricing OEM as more then $9 per seal. Where I can get them from BAP\GEON for only $1.40 per seal.
Anyone?
Anyone?
Bueller?
Seriously... I need some kind of answer on this as my heads are waiting for me to get the parts.
On these you get what you pay for. Here is the best I could do for you man.
90913-02094 intake seals $5.17ea
90913-02091 exhaust seals $4.70ea
Anyone?
Anyone?
Anyone?
Bueller?
Anyone?
Anyone?
Bueller?
What about head gaskets? and other seals and gaskets I will need for the rebuild?
Does the dealer replace head bolts? I think the Haynes repair manual claimed you should reuse them.
I don't think reusing head bolts is a good idea. If they are stretched out (likely at this point) you will probably blow a headgasket in the very near future and have to do this all over again.
While I have little experience with Toyota gaskets, my experience from working on other makes is that the OEM seals are almost always superior.
Bottom line: spend the extra money, do the job right the first time, it will save you headaches and money in the long run.
Vin
Send me your VIN and I will quote you whatever you need or want for your vehicle. This will just ensure we are on the same page.
On shipping, I try to stick to $6.00 if the package isn't over 3 or 4 lbs. That is shipped UPS ground and would probably reach you within a day since you are in Texas. All packages over $300 shipping is on me. Send me that VIN and we can get started.
TP
TP
Almost half of what the other dealers want. What about shipping?
4Runner
3.0L V6
4x4
Limited Edition
Transmision cooler
Tow Package
That should tell you just about everything you need to know and then some. If you still need the VIN, then I will have to get that tonight, but I could realy use the prices today.
I will always use OEM stuff when it comes to seals. I will never re-use head bolts even if the manual says its ok.
When I got my Celica's top end rebuilt, I went all OEM Toyota except I went with ARP head studs, since they are stronger.
Here is a list of things you might replace while doing your heads.
11116-65032 head gasket $51.50
11115-65033 head gasket $51.50
90311-42024 cam seal $4.32 ea x2
11213-65010 valve cvr gasket $8.71 ea x2
13568-69075 timing belt $23.35
90311-40022 crank seal $4.32
90311-92006 rear main seal $16.08
Hope that helps!
Hope that helps!
I actually can't get you that info right now, but I can tell you this:
4Runner
3.0L V6
4x4
Limited Edition
Transmision cooler
Tow Package
4Runner
3.0L V6
4x4
Limited Edition
Transmision cooler
Tow Package
justdifferentials
Just Differentials
09-17-2015 06:14 PM
1111565033, 9031192006, 9091302091, 9091302094, houston, oem, packer, representative, reuse, seals, service, texas, todd, toyota, valves
