Not sure what's wrong..
Old Nov 24, 2004 | 04:19 PM
az4x4runner's Avatar
Unhappy Not sure what's wrong..
Hey guys, last night after some snow wheeling, a friend of mine and I went somewhere to get something to eat, when I came out my truck wouldn't start. It acted as though the battery was almost dead or just had a really bad connection. He gave me a jump and I drove it home, however, I noticed that when I turned my headlights on it almost died again. The next morning I needed a jump as well, so after work I had it tested. The battery is fine, the shop charged it and the truck starts on its own now. I did a simple test to see if the alternator was working and it seems to be (read 12volts with car off and 13~14 with it idling). Any one have any idea what the problem could be? I kind of wonder if it really was just a bad conenction to the battery...
Thanks a lot,
Bryan
Old Nov 24, 2004 | 04:25 PM
leebee's Avatar
i had a similar problem, turned out to be a bad connection in the terminal/lug. replaced the lug, cleaned up the other one and the posts. now i just need to replace the little battery with an optima!
lee
Old Nov 25, 2004 | 10:09 PM
Scooter22's Avatar
It may be a dead battery. A fully charged battery should read 12.6 volts Here is a quick link. http://www.autobatteries.com/basics/voltage1.asp
Old Nov 25, 2004 | 10:30 PM
Yamaha+Toyota=Fun's Avatar
I had this happen on my truck one time too. I was the positive battery terminal and connector. I just hit it a few times with a wench and it fired up. Eventually I replaced it though. It seemed that it always acted up when i was wheelin around water.
Old Nov 26, 2004 | 03:30 AM
CAM 1's Avatar
Thanks a lot,
Bryan
A bad connection is what it sounds like. I was gona say mix up some bakingsoda and water and let it sit on the terminals. I had the same problem on my 94' (crud bildup = bad connection). Let the bakingsoda sit and watch it work Just my .02
Craig.
Old Nov 26, 2004 | 05:43 AM
AznSky's Avatar
just as everybody else said, i think it might be a bad connection too. Cuz last winter my connection went out on me as well. Spent a lot of time and $$ trying to diagnose the problem Ended up just having to replace the clamps and clean the terminals
Old Nov 26, 2004 | 06:59 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
How old is your battery? It may be cheap insurance to replace it if it's more than about 4 years old. I've seen cells recover after a good, "hard" charge, only to fail shortly after.
Old Nov 26, 2004 | 07:30 AM
shiftless89's Avatar
also check the water level in your battery! extreme temps (both cold and hot) will mess with a battery, especialy if it is low on fluid!
Old Nov 26, 2004 | 07:44 AM
Sofar it's been doing fine since I cleaned the terminals off. It use to act up before when I was wheelin around water until I replaced the positive battery terminal. I'm thinking it may be time to replace the nagative one as well. The battery isn't very old, I bought it in September because my old battery was dead (it was ancient).
Thanks for the input guys, I'll try cleaning them with baking soda until I can pickup a new negative clamp this weekend.
Edit: oh yeah, the fluid level is good..
70ssclone
Mar 5, 2023 07:47 PM
bigtoje
Mar 24, 2015 04:51 PM
LinguraDeLemn
Feb 7, 2012 09:36 PM
