Noisy engine
Old Feb 15, 2005 | 10:39 AM
KING's Avatar
Noisy engine
How to distinghish between noisy injectors, valvle taping, and pinging?
Old Feb 15, 2005 | 10:54 AM
ChickenLover's Avatar
Just a thought: The guys at my muff shop use some type of stethoscope rig to pin point exhuast leaks. You could get one of these, put it directly on one of your injectors to become familiar with it's sound. Then do the same on your valve covers. I bet this would help you distinguish between the two sounds. Pinging on the other hand, should be pretty obvious. While your engine is under load, it will sound like a marbel(s) bouncing around in your engine.
What are you driving by the way? I know on 2nd gen runners the steering shaft seal at the firewall commonly craps out leaving a hole directly into the engine compartment, letting all that normal engine ticking sound into the cab. Leading one to believe that there is an engine problem, when in fact it's just firewall seal.
Old Feb 15, 2005 | 11:07 AM
KING's Avatar
I would like to know how to distinguish the sounds without taking to a muffler shop, unless it is relatively inexpesive.
Taping, whether pinging or injectors, does tend to get relatively louder when the engine is under load.
I am having the injectors serviced and the timing belt will replaced soon so noisy injectors and any pinging ought to be brought to correction.
I am just concerned since the "taping" has been getting louder over the past week and a half.
I will check on the shaft seal.
It is a '94 P/U.
Old Feb 15, 2005 | 11:17 AM
rimpainter.com's Avatar
Noisy injectors will be pretty timed at idle on that motor. Noisy valves are somewhat harsh and "impromptu" if you will. In other words, not every one of your valves is going to be out of adjustment to the point of a perfectly timed tapping.
Most exaust leaks, depending on where they are, are timed. So, the sputter will be at a somewhat regular frequency until the engine heats up, which is usually when the sputtering subsides unless the hole is really big or it blew a gasket out.
Old Feb 15, 2005 | 11:26 AM
KING's Avatar
Got'cha on the valve part.
Interesting, I had never thought of that.
I am going to zero it down on the injectors.
I had never considered the exhaust and yesterday, whilde idling, I noticed the exhaust sound was almost replicant of a short-block 305 Chevy. Only a one time deal though, as it was normal this morning.
Sounds like I am a bit anal and paranoid on engine noise.
Old Feb 15, 2005 | 11:33 AM
Yeah, anal like me . You can also see if your truck is missing by taking a dollar bill and holding it up against the exhaust pipe outlet with the truck running at normal temp. A miss will "pop" the dollar bill nice and loud.
Sometimes out of adjustment valves will cause a slight miss that can be detected at idle.
Old Feb 15, 2005 | 11:34 AM
Join the club. If I have so much as a rattle in my glove box I get mad. When I first got my runner I was baffled by all the noise it made. I tried everything to correct it. I came to find out that the 3.0 is just a noisy sumbitch. That firewall seal made a big difference for me and I just finished adding a sound blanket to the firewall (engine side). So we'll see how that goes when I get the engine back together.
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
