noise in 4wd
noise in 4wd
I just recently bought a 1994 reg cab 22re yota. When I put it into 4H i get a loud noise/vibration above 25mph. I'm not sure if it's there in 4L. The manual says to check the torque of the driveline bolts....where are these?
I just changed the transfer case oil and that didn't help. Should I change the front diff fluid also? How do I check the u-joints?
Thanks for the help ....I'm new to the 4x4 world!
As for the u-joints if you grab the driveshaft with one hand on each side of the joint and twist in opposite directions there should be no play in the joint.
And I would go ahead and change tho oil in both diffs, unless you know for sure it's been done recently.
genuinegemini
08-03-2015 04:56 PM
Athansinis
07-27-2015 08:38 AM
ripp96
07-25-2015 02:32 PM
