New Tire Recomendations?
Old Nov 12, 2004 | 03:33 PM
Kcannaday's Avatar
Hey all, Wandering what tires you might recommend for my stock 99 4Runner for street and offroading use. I will be lifting it 2-3" in the near future!
Thanks to all who give a recomendation!
Old Nov 12, 2004 | 03:42 PM
lbb-1's Avatar
Revo's my friend.
Old Nov 12, 2004 | 03:49 PM
Kcannaday's Avatar
What size should I go with on my 16's with stock height or if I do a 2-3" lift?
Thanks!
Old Nov 12, 2004 | 05:51 PM
02SE's Avatar
I'm very happy with my Toyo Open Country AT's , in the LT 265/75R 16 size.
Old Nov 12, 2004 | 05:52 PM
Fink's Avatar
Try searching, there are 87230987934458 posts on this topic.
But Revo's sound perfect for you!
Fink
Old Nov 12, 2004 | 05:53 PM
ChickenLover's Avatar
Originally Posted by lbb-1
Revo's my friend.
Yep..
Old Nov 12, 2004 | 06:03 PM
Ilovemountains's Avatar
Thumbs up I say Revos
Revos here, I love them and I think you will also!
Old Nov 12, 2004 | 10:26 PM
Kcannaday's Avatar
Sounds like Revos then, but can someone tell me what would be a good size to go with. I'd like to go a little bigger but nothing to aggresive? Any suggestions.
Thanks!
Old Nov 13, 2004 | 12:17 AM
epic37311's Avatar
44's ....
Old Nov 13, 2004 | 01:12 AM
jimbo74's Avatar
i think a 265/75/16 will be good with that lift....
Old Nov 13, 2004 | 03:45 PM
Kcannaday's Avatar
Will 265/75/16's fit without the lift or do I need to lift it first to fit these tires under it. It has 265/70/16's on it now would the 75's be taller or wider.
Thanks for all the help!
Old Nov 13, 2004 | 04:51 PM
02SE's Avatar
My LT 265/75R 16 C's Toyo Open Country AT's fit fine on my stock height, with stock alloy wheels, Runner.
A 265/75R16, is approx. an inch taller than a 265/70R16.
The 265 is the section width of the tire in mm's.
The 75 is the aspect ratio, which means in this case that the sidewall height is 75% of the width.
R is Radial.
16 is the wheel diameter.
C is the load range, in this case a 6 ply tire.
Something else to keep in mind, is that not all tires branded a particular size are exactly the same actual size, there is usually some variation.
So you might try a particular tire on for size to make sure it will fit.
Hope this helps.
Old Nov 13, 2004 | 05:05 PM
Gangus2006's Avatar
I second that...
Old Nov 13, 2004 | 06:12 PM
Kcannaday's Avatar
R is Radial.
Hope this helps.
Thanks for the information!!
Old Nov 13, 2004 | 07:36 PM
VolcomTacoma's Avatar
BFG AT's They're exellent on/offroad tires and wear well. Donahoe even uses them on their doublecab race truck.
firstgen88
Oct 7, 2015 04:53 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
Scatterbrain
Sep 3, 2015 06:46 PM
128keaton
Sep 3, 2015 05:09 PM
matthew138
Sep 3, 2015 08:21 AM
