new set up im thinking abuot...
Old 03-05-2005, 03:14 PM
4unner4life's Avatar
Tell me what u think abuot this set up....
2 front tundra coils-----152$
2 rear coils (OME 890)-------139$
4 Rancho RSX adjustable shocks---168$
Old 03-05-2005, 03:46 PM
Localmotion's Avatar
I would say go with the OME shocks/struts.
Old 03-05-2005, 03:53 PM
so u say ome coils in the back and ome struts front and back....but with tundra coils up front...? thatll give the front 3inchs of lift and the back 2.5 right?
Old 03-05-2005, 04:01 PM
Im not positive about how much lift i got. But i pretty sure you'll be satisfied I used the the OME 891s in the rear and im content
matt
Old 03-05-2005, 04:47 PM
ok thanks matt
Old 03-06-2005, 02:24 AM
Bighead's Avatar
What makes you think you will get 3" of lift from the Tundra coils?
Old 03-06-2005, 04:40 AM
i thought i read someone sayin that
Old 03-06-2005, 06:23 AM
sschaefer3's Avatar
Tunrda coils give a 4WD vehicle 1.5" of lift. Add a top out spacer for an extra 1/2". For a grand total of 2".
The high point of the OME shocks is the huge piston shafts they have. The Ranchos are OK, but have the very small stock like shafts and the rear shocks are not as long = less travel.
Old 03-06-2005, 11:53 AM
I think i may just put OME coils all the way around...
Old 03-06-2005, 03:40 PM
User 051420's Avatar
Why? The Tundra coils are a proven solution..proven to work BETTER than the OME coils. You can add 2 top spacers to each side of the front, and you'll get 2.5" of lift. The ride will be awesome, and with OME shocks, it'll flex to the physical limits of the suspension. What else can you ask for?
Old 03-06-2005, 03:42 PM
sschaefer3's Avatar
I would not.
Old 03-06-2005, 03:48 PM
FilthyRich's Avatar
This is a no brainer. Read the million page thread, this setup works. So do other routes, but this seems to be THE ideal DD setup.
Old 03-06-2005, 04:25 PM
wouldnt two spacers kinda of preload the coil?
Old 03-06-2005, 04:26 PM
No. Read the threads on the setup. The spacers go outside of the assembly, with the longer studs. Buy the spacers from Andy (Bamachem).
Old 03-06-2005, 04:38 PM
sschaefer3's Avatar
Your not ready for a lift. You need to understand what you are doing more.
Old 03-07-2005, 09:22 AM
yea i kno im not going to get a lift soon im just trying to plan ahead....and learn some stuff
Old 03-07-2005, 09:23 AM
I just am starting to get into all this so sorry if my questions are kinda stupid.
Old 03-07-2005, 09:27 AM
bamachem's Avatar
we all have to start somewhere.
however, you have a ton of info at your fingertips. do a couple of searches and read all you can, then go back and read them again. you need to absorb the info and learn what's going on. when that's all said and done, then you can ask INFORMED QUESTIONS and get relevant answers. been there, done that. OME works. TUNDRA TRD works BETTER
Old 03-07-2005, 09:34 AM
Ok thanks
Amer
3.4 Swaps
19
06-05-2017 10:43 AM
DrZero
18
07-24-2015 11:31 PM
akaphilly
07-09-2015 02:27 PM
MTLroadierunner
07-06-2015 12:17 PM
karbin
07-05-2015 11:37 PM
Quick Reply: new set up im thinking abuot...
