New Rockers for the cam
Old 06-02-2005, 12:17 PM
Dezertoyota's Avatar
My rockers are wasted...Are there companies that make aftermarket aluminum rockers for the 22re engines? If so who? Dont want to spend Toyota $$$ price since its my DD.
Old 06-02-2005, 12:51 PM
4Rocker's Avatar
Go Toyota. I tried reusing some of the rocker arms after installing a new cam, and a year later the cam was worn and groved. I ended up replacing the cam again, as well as buying all new rocker arms. I HIGHLY recommend just going with the toyota ones the first time.
Old 06-02-2005, 01:02 PM
Im getting new ones for sure just wan't sure if there is any aftermarket companies making them
Old 06-02-2005, 07:23 PM
kyle_22r's Avatar
not sure about toyota's pricing, but they're not *that* expensive when you compare the price of new rockers for a toy to a set of rockers and lifters for a domestic engine. most parts houses should be able to at least order them(i think the going price is $10 an arm or so?), and i think engnbldr carries them.
Old 06-03-2005, 06:48 AM
4Rocker's Avatar
When I got them from the dealership, the rockers were about $25 each.
Old 06-03-2005, 08:07 AM
Im only finding listings in our books for rockers only for a 90 22re. I have a 93 22re...I think for my year I need to get the rockers AND the shafts together. Is this the case???
Old 06-03-2005, 11:58 AM
DudeBud's Avatar
no you have to get them seprate then put them on your shafts
Old 06-03-2005, 05:57 PM
kyle_22r's Avatar
all rockers 1983-1995 are the same. 75-95 are interchangeable, but '75-82(20R and first 2 years of 22R) have steel rockers that are noisier and don't wear as well as the aluminum ones.
Old 06-07-2005, 10:38 PM
Thanks for the help it turned out the book was misprinted and only labeled the rockers individualy for the 1990 22re.
Aftermarket rockers were $17 but no one carried them so I went Toyota for $22 each plus $2 each resale for the set screws.
LittleUgly
15
01-02-2020 01:30 PM
moparbay
10-06-2015 09:24 AM
tylermx71
09-29-2015 08:49 PM
whiteyota93
09-29-2015 02:31 PM
voiddweller
09-28-2015 11:21 PM
Quick Reply: New Rockers for the cam
